Author Topic: Boot lift handle  (Read 3860 times)
Re: Boot lift handle
« Reply #15 on: 06 August 2012, 08:53:32 »
I hope you understand the above, it's just the middle bit that you lift that has a sheared pin. I would take it off , have a look, and either replace the pin, or swap the complete handle assembly. (remember to keep your old lock)
Ok understood agemo , will let you know how i get on and thanks for the helpful hints  ;)
« Reply #16 on: 08 August 2012, 12:59:23 »
Just to update , i removed the handle and all the pins were intact , i lubed the spring mechanism and pushed it back ...seems to have worked a treat and all fitting snugly .
Many thanks for the help  ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #17 on: 08 August 2012, 14:05:23 »
Job's a good un then.  :y
Does the handle sit straight now then?
« Last Edit: 08 August 2012, 14:06:59 by Agemo »
« Reply #18 on: 08 August 2012, 17:40:23 »
Yeah , after i soaked the spring mechanism then it just seemed to pop back into place ...nothing seems to be broken and all sitting square now  :) Strange  :-\
Page created in 0.023 seconds with 20 queries.
