cambelt change in devon
Started by scottambrose, 08 August 2012, 21:46:50
amba
He,s your man...sure he will do you a much better deal than that garage and it will be fitted correctly :y
sorry, been working away.... if you can get the part at short notice, I can fit you in Monday!  :y
Price and further info sent by PM. It will cost you around half of that garages quote  ;D :y
JimE
Quote from: plym ian on 09 August 2012, 19:20:27
it's called euro service by lee mill just behind the jet garage. its owned by my bosses brother and he is a great mechanic, if there are jobs I can't do he will do it and at a good rate to. I'll pm you his number if you want just tell him Ian at big pine recomended you he should look after you.
hope this helps :)
That the same place that does Citroens?  If so had dealings with them in the past and was very pleased with them.
scottambrose
Quote from: JamesV6CDX on 11 August 2012, 16:44:26
this mans a legand hes coming today to do the job and like he said bloody cheaper than vx wanted and he will do it right.
this forum is a god send.
taitinson
James is definitely the man for the job, really knows his stuff :y
amba
Don,t go giving garages your money ;D when you can get it done properly on this forum.
Well done James :y
scottambrose
hopefully hes going to post some pics up later but lets just say vauxhall did a crap job last time and james said im lucky to not have bent valves
amba
So spent less money and got the job done properly  ;D ..sounds like a result   :y
Yep, I will post up some pics later..
Given the last cambelt was done by a VX dealer, it was an utter disgrace..  >:(
My first thoughts when I saw how far out the cams were when the crank was at TDC, were "how the break is this thing even running"  :-X
All timed up to perfection now and running sweetly. I bet you that flat spot will disappear now, scott!! :y
scottambrose
Runs sweet now thanks mate your,a star
Steve B
Quote from: JamesV6CDX on 13 August 2012, 17:12:05
bet you glad you never went there ;D ;D
Quote from: scottty on 13 August 2012, 19:03:43
Has the flat spot / hesitation gone? :y
scottambrose
Yer its lovely and smooth now mate can yoi pit.them pics.up so I can see how.bad.it.was
Quote from: scottty on 13 August 2012, 22:05:23
Will do (as soon as I can locate the USB cable for my camera phone) ;D :y :y
Webby the Bear
honestly, these vx dealers get worse. i like the ''if we find any oil leaks it will be more'' lol wtf has oil leaks got to do with a cambelt change!
fekkin retards
RIP Paul Lovejoy
