Author Topic: Rocker cover  (Read 3436 times)
Re: Rocker cover
« Reply #15 on: 13 August 2012, 18:22:31 »
Personally, I wouldn't bother with the alloy covers. It moves the problem to a much worse, much more expensive place.
People bang on about genuine parts. In this specific case, they are right. 99.9% of those using pattern parts get them to last less than 6 months. I doubt the other 0.1% realise they are leaking ;).
As the using garages, we hear it time after time here - "its a mate, he knows what he's doing" or "he's a Vauxhall trained mechanic" or similar, it always results in the same, a bodge job that doesn't last. Virtually nobody knows how to do this job, purely due to laziness/stuborness/stupidness, and cannot be bothered to read how to do it. Thus, I would sincerely recommend you do this yourself.
Key points:
Genuine gaskets and o rings, without fail. Critical.
Clean sealing areas, critical.
Black sealant in the correct places, and not blocking the drain holes. Critical.
8Nm on the cover bolts. It cannot be guessed, no matter how big a cock a mechanic thinks he has. Critical.
Clear breathers. Critical.
Obviously, if some ham fisted mechanic has been in there and buggered the covers, they need replacing. Plenty of good 2nd hand ones out there.
How long will the breathers stay clear - depends on usage, servicing and oil used. Long journeys, 3k oil changes and a good quality oil (ie, not Castrol) should mean you only need to check annually.
Re: Rocker cover
« Reply #16 on: 13 August 2012, 18:23:46 »
I should add, being an Omega specific forum, with some very, very talented members, we have the luxury of understanding this car better than any backstreet mechanic.
CHRIS Dewey
  • DONCASTER
    • Omega elite
Re: Rocker cover
« Reply #17 on: 18 August 2012, 11:56:06 »
can anyone tell me were i can get some genuin gaskets other than from the dealer
Re: Rocker cover
« Reply #18 on: 18 August 2012, 12:14:47 »
Only available from dealers Im afraid.If you send a PM to AndyC on here,he works at a dealer and may well be able to do a bit of a deal on the price. Delivery from Andy is usually very quick. :y
  • Auckland
    • Mazda MPV
Re: Rocker cover
« Reply #19 on: 18 August 2012, 12:19:24 »
Unfortunately not :(
The best we can do is recommend that you join a club that gives you access to TradeClub prices at a VX dealer (Autobahnstormers @ £25 per year)
or mail order from andyc who is parts manager at a VX dealer and can offer trade price (plus postage  :() Drive Vauxhall - Bury St Edmund
