Author Topic: coolant level warning  (Read 1880 times)
hawksy
  • crewe
« on: 11 August 2012, 20:15:13 »
driving home this afternoon coolant level came up on mfd , i stopped the car and checked but level was ok and temperature was ok . the car is a 2003 omega elite 2.2dti with 217,000 miles on it , i bought it 5 years ago with 34,000 and it has never missed a beat , could it be a faulty sensor or the start of trouble to come, regards mike
Re: coolant level warning
« Reply #1 on: 11 August 2012, 20:22:14 »
If coolant level is ok but your getting a "coolant low" message then its probably a faulty sensor,which is quite common.Might be worth pulling/pushing the sensor up/down a few times in case its just got a bit stuck,but apart from that the header tank will need to be replaced. :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 11 August 2012, 20:22:44 »
Pretty common fault, the sensor is fitted to the bottom of the reservoir, and they don't like being disturbed. Either get a replacement from a breaker on here, or go for a new one, apparently about £30 from Vx.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 11 August 2012, 20:23:31 »
Sounds like the sensor, or could be stuck, is it floating ok, have a poke about.
Worth noting some Garages bodge faulty sensors in the past buy putting a paperclip to short the connector, paperclip rusts off showing a low water warning.
hawksy
  • crewe
« Reply #4 on: 11 August 2012, 21:01:23 »
cheers , had a poke around pushing and pulling but mfd still displaying coolant level and check light , so sounds like new sensor / header tank
Big_Al
« Reply #5 on: 11 August 2012, 21:50:55 »
Easy test is to pull sensor wiring  connector out from underside of header tank & link the two connections with a short piece of wire .
Warning should go out . Remove link wire & warning should come on again .
No need to drain coolant  at all      HTH  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #6 on: 11 August 2012, 22:39:05 »
get your £38 out your wallet  :y :y :y :y
