Pages: 1 2 [3]  All   Go Down
Author Topic: LPG kit choices.. or..  (Read 7211 times)
Re: LPG kit choices.. or..
« Reply #30 on: 14 August 2012, 14:27:51 »
Aaron, as I'm nowadays busy with a friends mondeo with all sorts of LPG problems, I'll recommend, you renew every ignition component and alternator including battery before LPG .. or you may end up with all sorts of weird problems.. :(
Not necessary unless it has previously been neglected. I'd advise new plugs unless they are under 15k old but other things should be OK if they have been maintained properly in the past :y
« Reply #31 on: 14 August 2012, 14:37:52 »
Yep, no need to go mad replacing things.
Of course, if you start a conversion on a car that already has issues, you will end up in a mess, but no sense in replacing parts on the offchance that they might turn out to be faulty IMHO.
« Reply #32 on: 14 August 2012, 16:24:04 »
The single reason I've not done mine yet :y
« Reply #33 on: 14 August 2012, 16:31:30 »
Yep, looks OK. KME reducer, so all that kit is well proven on an Omega.
Can't see a serial lead for connecting it to a PC, but that's not a big issue. You'd need a few extras, and tank+filler+polyflex+mounting hardware. It would work out more expensive than Teilo's kits, I think, but.. you can actually buy it. ;)
It seems that the tank and plumbing are readily available from them at the checkout :y what isn't clear is any extra cost for them :-\
« Reply #34 on: 14 August 2012, 17:37:35 »
Mention nozzles cripple. Even if he sends them to you, at least it's a step forward
Was just about to text you about them ;)
He answered! But busy, now awaiting a call back ::)
As expected, it never happened >:( >:( Although I was too busy to chase him this afternoon ::) ::)
I'll try chasing him tomorrow ;)
« Reply #35 on: 14 August 2012, 18:54:06 »
I owe him an apology! The return call has come in. Aaron and TB, you both have PM ;)
For the record, he is no longer supplying AC Stag kits (apart from what's in stock) but is moving to a new, better, more cost effective supplier :y
« Reply #36 on: 14 August 2012, 21:27:17 »
Thanks CrippleBack. I still like Cakey more, as she does nicer presents for me ;D
Thanks LD
Pages: 1 2 [3]  All   Go Up
