Author Topic: 2.0 16v Auto (LPG) - EML on and car in limp mode  (Read 5448 times)
Re: 2.0 16v Auto (LPG) - EML on and car in limp mode
« Reply #15 on: 14 August 2012, 19:19:43 »
Just doublecheck that the flash code is 10-3-4-10  (0340) :)
Guinney1971
  • Nottinghamshire
    • Renault Grand Scenic
« Reply #16 on: 14 August 2012, 21:18:48 »
will do it again tomorrow, when we did the paper clip test tonight it did keep repeating that sequence however.
cheers,
Claire
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
« Reply #17 on: 14 August 2012, 21:37:26 »
Cam sensor is likely, but check with paperclip in morning :)
Quite easy to change if it is.
Guinney1971
  • Nottinghamshire
« Reply #18 on: 14 August 2012, 22:30:14 »
Have come to the conclusion that I'll need to take out the old sensor to find out which type I need to order from Vauxhall, as I dont know if my car has the modified one or not.
Its all good fun, eh!!  ::)
Claire
Claire & Phill
Guinney1971
  • Nottinghamshire
« Reply #19 on: 16 August 2012, 13:45:57 »
I've removed my old cam sensor this morning - it is the modified type - I then fell off my chair when Parts Bod at local Vauxhall Dealer said he had them in stock at £60 inc VAT !!!   :o
Quick trawl of t'internet, turned the correct one up, for £25 plus a bit of P&P, so I'll stick my feet up and wait for the Postie to bring it to me, and in the mean time use my DeLorean as the daily driver!   ;D  ;D  ;D  ;D
Claire
Claire & Phill
« Reply #20 on: 16 August 2012, 13:50:14 »
It might well be fine... I know for crank sensors, gen GM is a must - not sure if this applies to cam sensors too....  :-\
Guinney1971
  • Nottinghamshire
« Reply #21 on: 16 August 2012, 13:51:28 »
this is a gen one, same Siemens part number and branding as my old one  :)
Claire
Claire & Phill
