Author Topic: servo pipe  (Read 3022 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
servo pipe
« on: 15 August 2012, 06:21:16 »
Should the brake servo pipe be" loose"at  the engine end? While the nut that goes into the plenum is tight I can hold the pipe itself and rotate it as far as any free play allows,is this right or should the pipe be immovable?
Re: servo pipe
« Reply #1 on: 15 August 2012, 08:33:29 »
There can be some slack (enought to rotate the pipe) on some where the plastic part fits over the metal fitting.
The key thing is that the unions are tight and that its not worn through where it passes the aircon pipe at the rear right
Re: servo pipe
« Reply #2 on: 15 August 2012, 08:45:55 »
As long as there's no air leak...?
  • Online Online
Re: servo pipe
« Reply #3 on: 15 August 2012, 08:53:26 »
best if there's no vacuum leak though ..........  ::) ::) ::)
Re: servo pipe
« Reply #4 on: 15 August 2012, 08:58:29 »
...of air! ...or should that be pir ...? Mr P from Pury. ;D
Re: servo pipe
« Reply #5 on: 15 August 2012, 10:02:11 »
[pedant]
I thought vaccum consisted of nothing at all, so how can it leak anywhere?
[/pedant]
twiglet
  • Norwich, Norfolk
Re: servo pipe
« Reply #6 on: 15 August 2012, 12:25:16 »
Technically it would still be an air leak, except the air (at atmospheric pressure) would be leaking into the pipe rather than out of it.  :y
Re: servo pipe
« Reply #7 on: 15 August 2012, 12:44:48 »
[pedant]
[/pedant]
capital P Kev. CAPITAL"P" ;D ;)
