Author Topic: Air locks in coolant system  (Read 3388 times)
Re: Air locks in coolant system
« Reply #15 on: 16 August 2012, 13:33:02 »
There is 2 connections on the rad that screw in on the passenger side , one of mine needed nipping up tight to stop a leak when the system was pressurized ...check those as well  :)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #16 on: 16 August 2012, 13:35:16 »
Good thinking, Batman..... ;D
Yes...I think pressure test is order of the day :y
I'll keep you posted ;)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #17 on: 20 August 2012, 23:29:01 »
Rad pressure tested.......pressure did not drop :(
However, after leaving the engine running for a while, then revving, I noticed a small jet of water shoot out from in between the fan blades. Did another pressure test, and still no drop. Weird.
Drove to Brackley, temp started rising as I joined A43, then had to wait at roundabout, and temp went into the red. As I pulled away, coolant warning came on, so stopped in layby, cooled down, topped up and continued to Brackley...no probs.
Pressure tested again ....no drop >:(......but again, noticed another small jet through fan.
Came home today.....ran ok till Wycombe, then temp up slightly, till I stopped at traffic lights, and temp went into red, but no coolant warning.
Did the last three miles with clenched buttocks, but got home ok. This time, under the bonnet was well wet, so have put a new rad in. :y
Just hope nothing else is broke as temp went so high (the fans did cut in)
Could water and anti freeze on the aux belt make it slip and the new water pump not work ???? Why did the temp go into the red, with fans working :(
« Reply #18 on: 21 August 2012, 09:12:49 »
Not enough coolant for it to circulate through engine and rad. properly.
Page created in 0.041 seconds with 16 queries.
