Pages: [1] 2 3  All   Go Down
Author Topic: judder  (Read 6537 times)
scottambrose
judder
« on: 18 August 2012, 19:56:01 »
I had bad judder under braking from 60 so today changed the.front discs which looked almost new but I still habe slight judder. Ive also got a bit of judder and vibration at 55mph like a wheel is unbalanced but not too noticeable
Re: judder
« Reply #1 on: 18 August 2012, 20:27:52 »
if they are not brand new you cant be sure unless they are tested in a machining shop.. but also you may have balance issues.. so a full geometry check will help imo..
scottambrose
Re: judder
« Reply #2 on: 18 August 2012, 20:31:59 »
Its got brand new ones now but the,ones I took off looked less than a few months old its alot better but still slightly juddery
Re: judder
« Reply #3 on: 18 August 2012, 20:38:01 »
ops.. sorry for misunderstanding.. must read slower..
in that case you need full geometry check.. can be anything..
SteveAvfc.
    • Mv6 2.6 V6
Re: judder
« Reply #4 on: 18 August 2012, 20:48:45 »
As Cem says a full geo set up would be your best option Wheels in motion are the people you need to see. You don't say what part of the country your from but they have franchises all over the UK.
Worth every penny.  :y :y
  • Auckland
    • Mazda MPV
Re: judder
« Reply #5 on: 18 August 2012, 21:20:09 »
What make of discs have you fitted?
My personal experience has been that fitting anything other than genuine Vauxhall is a bit of a lottery. One pattern set I fitted juddered from new >:(
Re: judder
« Reply #6 on: 18 August 2012, 21:30:26 »
Cant see how full geo set up will help with brake judder guys.
They might be able to do a better job of wheel balancing with their 5stud balancer system though. :-\
scottambrose
Re: judder
« Reply #7 on: 18 August 2012, 21:33:54 »
Could rear brakes cause steering wheel judder
Re: judder
« Reply #8 on: 18 August 2012, 21:35:22 »
Could do if it's bad enough but the whole car will be juddering too. Sounds like front to me.
SteveAvfc.
    • Mv6 2.6 V6
Re: judder
« Reply #9 on: 18 August 2012, 21:39:13 »
Agree but he has also got issues at 55mph which could possibly be wheel balance issues. So after he gets the judder sorted a full geo set up would help would you agree.  :y :y :y
Re: judder
« Reply #10 on: 18 August 2012, 21:41:53 »
I would :y
plus any car used daily drops in a pothole and your balance is gone :-\
Re: judder
« Reply #11 on: 18 August 2012, 21:45:15 »
Won't make an ounce of difference to wheel balance or judder on the brakes.
If there's a handling issue though, then yes it will help. Although there's no mention of that in this thread.
Re: judder
« Reply #12 on: 18 August 2012, 21:46:54 »
Wheel balance is not included in full geo set up. That's a seperate process.
Re: judder
« Reply #13 on: 18 August 2012, 21:47:04 »
Re: judder
« Reply #14 on: 18 August 2012, 21:47:44 »
then its not a full geo setup Chris
Pages: [1] 2 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
