Pages: 1 [2] 3  All   Go Down
Author Topic: 2001 (Y) 2.2 Auto ECL and strange gear change  (Read 11135 times)
steve6367
Re: 2001 (Y) 2.2 Auto ECL and strange gear change
« Reply #15 on: 21 August 2012, 15:18:42 »
Thank you
Strange then, defenitly CDX and face life, but no HDI headlights. They look well aged and original too. I shall investigate further.
Steve
« Reply #16 on: 21 August 2012, 15:19:55 »
"Low Beam Fld/Vision"
If the HID`s have been replaced with "standard" lights you`ll need a TechII session to re-program the MID to get rid of that fault message
steve6367
« Reply #17 on: 21 August 2012, 15:36:13 »
Update - the adjuster wheel does not seem to adjust the headlights. Pointing at garage door and no movement detected.
« Reply #18 on: 21 August 2012, 15:44:53 »
You sure they`re not HID`s ???
steve6367
« Reply #19 on: 21 August 2012, 15:52:24 »
100% - they have. Standard filament halogen lamp in them and the colour temp is too warm for a discharge lamp.
Steve
« Reply #20 on: 22 August 2012, 11:45:40 »
Adjuster wheel isnt dimming dash backlighting?
steve6367
« Reply #21 on: 22 August 2012, 17:00:39 »
Dash lighting dims ok - it is the headlight height adjuster that does not work.
I also note that the holding onto gears does not happen form a cold start, only once warmed up.
Steve
steve6367
« Reply #22 on: 30 August 2012, 10:07:48 »
I have heard from Kevin and will fit in a trip when time allows. Been digging a little deep however.
On the lights, this wiring does not look original to me, any comments?
http://db.tt/zLJP6sSx
http://db.tt/N3jre8qH
With the Lamda and throttle position error, I have discovered a crack across the top of the exhaust manifold. Could this be part of the problem? Itis blowing as you can feel hot gas escape when running. Clearly I will have to change it.
Steve
« Reply #23 on: 30 August 2012, 10:15:11 »
Steve
HID`s have been replaced with standard projectors
steve6367
« Reply #24 on: 30 August 2012, 10:19:27 »
Fair enough, just need to work out how to get the level adjustment to work now! Are there any wiring diagrams available anywhere?
There are 2 multiple connectors on the lights but without knowing what does what it is hard to test.
I guess whoever changed them in the past tried to get manual level adjustment as the rotary switch is there on the dash.
Steve
steve6367
« Reply #25 on: 30 August 2012, 10:20:07 »
Photo of cracked manifold:
http://db.tt/5tK0a90h
steve6367
« Reply #26 on: 30 August 2012, 14:48:53 »
Went to local scrap yard and found 2.2, but removing the heat shield I found:
http://db.tt/kzzKdkTH
Clearly a common problem then?
Did manage to get some other useful bits however :-)
Steve
mga32
  • poole
    • 2.2cdx
« Reply #27 on: 30 August 2012, 15:18:55 »
If you are in bournemouth, trents have a v6 with HIDs still fitted in there yard (pick a part), You will have to remove them yourself, but I doubt they would cost much.
« Reply #28 on: 30 August 2012, 15:21:04 »
Steve
With your present set-up you won`t. Retroffiting HID`s to a basic spec (GLS or CD) you keep the existing level motor for the manual adjustment. In your case it appears the previous owner has fitted standard projectors + level motors and swapped the main lightswitch over. Manual adjustment will not work as the loom for HID`s is different in that it encompasses the front & rear level sensors and the HID ECU makes automatic level adjustments via signals received from both of them. You may get the auto-adjust to work by fitting the HID level motors and ensuring both sensors are operating correctly, failing that it`s a case of getting the headlights adjusted to an MOT standard and leaving them at that.
mga32
  • poole
    • 2.2cdx
« Reply #29 on: 30 August 2012, 15:24:37 »
You could check to see if you have a level sensor mounted on the passenger side wishbone to make sure someone just hasnt added an X to the CD!
Pages: 1 [2] 3  All   Go Up
