Author Topic: 2001 2.2 CDX interior light  (Read 2824 times)
steve6367
« on: 23 August 2012, 08:39:58 »
A couple of question about what is normal behaviour.
When I unlock the car with remote all interior lights come on, but not for long. If I open either front door just the low level door lights come on. Rear doors the rear reading light for the side the door opens comes on.
I imagine the main interior light should come on when doors open? Can anyone tell me in the above is normal?
Thanks
Steve
Re: 2001 2.2 CDX interior light
« Reply #1 on: 23 August 2012, 15:45:49 »
Interior light should come on when front doors open
steve6367
« Reply #2 on: 23 August 2012, 16:42:42 »
Thank you, as I suspected :-)
Does anyone know how it is controlled? I guess it is not just by the switch as that seems to manage to turn on the low level doors lights. Is it another Tech 2 programming thing?
Stece
« Reply #3 on: 23 August 2012, 16:49:12 »
Swap the rear door push switches to the front see if it works then
« Reply #4 on: 23 August 2012, 16:54:35 »
Driver's is a double contact switch ......at least my Omega is & the Senators were before it.  ;)
steve6367
« Reply #5 on: 23 August 2012, 18:48:38 »
Thank you both, that makes more sense.
I'll try and swap and then investigate if both contacts are working.
Steve
« Reply #6 on: 23 August 2012, 20:06:31 »
Bulb ok? ;)
Ignore - just read 1st post properly :-[
« Reply #7 on: 23 August 2012, 20:07:39 »
Bulb ok? ;)
« Reply #8 on: 24 August 2012, 13:30:30 »
Bulb ok? ;)
Yep don't rub it in Rob  ::) :) :) :) ;)
steve6367
« Reply #9 on: 28 August 2012, 18:09:51 »
Just taken all 4 door door switches out, 2 wires on each which both close to ground through the fixing screw. In my case only 1 pole was doing this - some WD40 and vigorous cycling of the switch and they now all work :-)
« Reply #10 on: 28 August 2012, 21:26:01 »
Nice one mate  :y
