Author Topic: Number Plate Lamps u/s  (Read 2607 times)
« on: 24 August 2012, 11:30:04 »
As above :-\
Have tried:
New bulbs
Tailgate wiring ok
Seems to be no power to number plate lamps at the tailgate loom plug in nsr quarter
Rear wiper works
Heated rear screen works
Tailgate central locking works
Sidelights working front and rear/left and right
All fuses okay
Only other light out is the bulb for the EML
TIA,
Electrically challenged of Sussex
tidla
  • solihull
Re: Number Plate Lamps u/s
« Reply #1 on: 24 August 2012, 20:15:02 »
Connectors between the fuse and the bulb.
from top.
pass comp fusebox.
l/h a pillar
2 connectors in tailgate.
edit , change the fuse anyway for a new one.
« Reply #2 on: 25 August 2012, 00:17:58 »
Ta :y
Will change fuse and check connection in the pax foot well.
Tailgate connections sound.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 25 August 2012, 10:10:27 »
Will...check connection in the pax foot well.
Going by 'tidlas' post there are no connections in the footwell area.
One is in/near the fusebox in the cabin, and the other is under the n/s trim that goes up along the windscreen, thats my understanding of his post anyway...
« Reply #4 on: 26 August 2012, 02:13:04 »
Should be a circuit driven by a relay switched by the headlight switch, then through the fusebox , across the dash, down pax a post, along pax sill and up the d post into tailgate :-\
working back from the lamps conection are:
1 lamp unit
2 plug within tailgate
3 plug in nsr quarter
4 plug at base of a post
5 fuse box
Thats all the joints  i've found :-\
  • Auckland
    • Mazda MPV
« Reply #5 on: 26 August 2012, 09:37:39 »
On my previous Omega (saloon) the flexible wires by the boot hinge had snapped through stress fracture. I had to cut the wires back and solder in a new section.
« Reply #6 on: 26 August 2012, 18:54:52 »
Double checked fuse 26 and found it blown ::) kind of assumed that they were powered through the tail lamp fuses, l and r ::) :-X
Still, all sorted  :y
Ta muchly :y
Brikhead
  • West-Mids.
« Reply #7 on: 26 August 2012, 20:26:41 »
Have tried:
New bulbs
Tailgate wiring ok
Rear wiper works
All fuses okay
Glad you sorted it. :)
