Author Topic: Thanks to that Gixer fella  (Read 16429 times)
Re: Thanks to that Gixer fella
« Reply #30 on: 27 August 2012, 21:50:28 »
Anyway, we've fitted another set of wheels now, so the offending article(s) will be in the skip shortly. :y
But what tyres to replace them with ...?
Having varified the mileage on mine to some extent, going by the fitters records. I vote sc3's given TB's ... enthusiasm.
And? What was this mileage as I'll be looking for new tyres soon ::)
« Reply #31 on: 27 August 2012, 22:05:53 »
Gayboy reckons 20k. Which I must be honest is impressive. But then he drives like a girl :P
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #32 on: 27 August 2012, 22:18:44 »
Looks like the MOT tester should've gone to specsavers
SMD
  • London
    • :( nowt
« Reply #33 on: 27 August 2012, 22:25:52 »
Falken tyres, recommend 912 and 452. Brilliant tyres, suit the Omega IMO.  :y
« Reply #34 on: 27 August 2012, 22:29:54 »
But what tyres to fit...?
Thats a good question ::)
Although, I'm disturbed about these splits, as I'm pretty certain they were not there last year, and fairly certain they were not there 3 weeks ago  :-\
Are the Nexen 6000's prone to this type of failure?
a pic perhaps?
Ld. Micheldever records show 15k since last visit. Which was when the sc3's where fitted to the refurbed wheels on my current car, going by the recorded reg.
But they where also fitted to my previous car for some time, on different wheels.
So my previous noted figure, that I didn't believe, of just over 20k does seem to be about right. It is a bit vague though tbh. So make of that what you will.
Weather they will hold the same wear rate on a different commute is another story. My journey to work has 12 corners and in time (not miles) is 50% motorway.
Although at 5am :-X
However I do think the grip v wear rate is impressive tbh. Bit expensive, but if they last that long, and perform reasonably well, then it's a cost worth paying.
Note, they are worse than useless in snow.
« Last Edit: 27 August 2012, 22:36:17 by chrisgixer »
« Reply #35 on: 27 August 2012, 22:34:52 »
Certainly more impressive than the 6k I got from my rears, fitted in Feb/Mar.  Although I reckon I've had more fun...
« Reply #36 on: 27 August 2012, 22:41:30 »
In fact they had been on for some time at the lakes, year before last meet. Iirc, as Clifo B pointed out the outside edge wear on the fronts.
And as you saw today TB, there is still ample tread depth left in the middle of those two fronts. Although the edges have gone, they still drove quite well with minimal tram lining.
(a bit extra toe setting might be a way forward, to counter the normal inside edge wear)
« Reply #37 on: 27 August 2012, 22:43:32 »
6k. So times 4 of those to one sc3 maybe? Do the sums add up?
« Reply #38 on: 27 August 2012, 22:45:22 »
20k+ does make them appealing... Although I reckon I get similar mileage from the Acceller Alphas I have been using which have provided sufficient grip for the capabilities of the wallowy Elite suspension :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #39 on: 27 August 2012, 22:45:45 »
I'm heading for the slit trenches!  ::) ::) ::)
« Reply #40 on: 27 August 2012, 22:54:53 »
so that's no good then, aye.  ;)
« Reply #41 on: 27 August 2012, 23:01:32 »
But I have the local BP to contend with ::). Or worse, Shell Leadenhall, they are a bunch of useless 'tards. Plus Milton Queens, roundabout city.
So, the question is, how long would SC3s last me?  I reckon, although its from memory, my SC3s on MV6 lasted about the same as the SP9000, so about 12-15k on a 235/45/17 profile. Suspect a lower profile would wear a bit quicker?
« Reply #42 on: 27 August 2012, 23:02:20 »
Were those the tyres you had on going to Wycombe meet  :-X
« Reply #43 on: 27 August 2012, 23:06:42 »
And another thanks to that Gixer bloke, for getting me out of a hole after discovering 3 splits on the inner sidewall of a 2yr old Nexen 6000 tyre. Thanks Mr Gixer, for your hospitality today, and for discovering yet more crap wrong with my inferior facelift model :P
Eh? Did not know you had Nexens same as mine?
« Reply #44 on: 27 August 2012, 23:09:40 »
I only had one on my Heinz 57 equipped car. Replaced the lethal Autogrip.
