Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: GINETTA G27 HYBRID BUILD FROM OMEGA V6  (Read 27562 times)
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
Re: GINETTA G27 HYBRID BUILD FROM OMEGA V6
« Reply #60 on: 01 October 2012, 13:14:21 »
A bright chassis, i'm up for most things, but i think i'll keep it conventional chaps !
« Reply #61 on: 01 October 2012, 15:16:20 »
Paint it all in a zionc rich etch primer before applying a colour coat as well, it helps a lot to protect the un-galavanised sections after the inevitable stone chips.
And dont forget to write 'Please Turn Over' on the underside.
« Reply #62 on: 01 October 2012, 17:31:01 »
That's cruel!  ;D ;D ;D ;D ;D
markrnorton
  • Essex
« Reply #63 on: 01 October 2012, 21:31:09 »
Well still not sure abou the chassis, will dwell on it a bit
Need to get the rear end on and get a rolling chassis. I can start positioning the v6 and gearbox then
« Reply #64 on: 02 October 2012, 08:07:00 »
That's understandable ;) I really don't know why I'd be tempted to go bright :-\
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #65 on: 02 October 2012, 16:05:28 »
Just don't ask Daz for any colour suggestions.  ;D ;D ;D ;D
fregis
  • Lithuania
    • x25xe
« Reply #66 on: 31 October 2012, 15:26:30 »
do not think about Ford Sierra / Scorpio diff?
aluminum light weight and a lot of them are
markrnorton
  • Essex
« Reply #67 on: 31 October 2012, 16:17:14 »
Sorry, not quite understanding you
« Reply #68 on: 31 October 2012, 16:36:58 »
Guessing the final bit was 'LSD'
Trouble with the Ford diffs are that they are getting very hard to find with only the XR's and Cosworths having LSD's of useable ratio.
fregis
  • Lithuania
    • x25xe
« Reply #69 on: 01 November 2012, 00:07:15 »
Yes, i forgot mention LSD  ;D
Not necessity cosworth, i found scorpio 2.0, 2.3 was lsd with 3.91 ratio  ( or can find open 4.27 ratio (from 2.0 16v scorpio) and mix with lsd from lower ratio)
sierra 2.0 4x4 3.92 with lsd ant a lot of other.
« Reply #70 on: 01 November 2012, 00:19:01 »
Mine came from a 24v Scorpio and is 3.64 LSD.
There's also a company refurbing the viscous LSDs for reasonable money now. I'll have to dig out the info.
markrnorton
  • Essex
« Reply #71 on: 01 November 2012, 12:52:09 »
As Mark DTM mentioned, the ford diffs are getting more difficult to find and come at a cost.
The Nissan set-up is freely available, takes loads of power, is an lsd as standard (some models) and cheap. The rear hub/brake set-up with the half shafts is also pretty good.
Just couldn't see the point of the ford. maybe 10 years ago, but not now.
markrnorton
  • Essex
« Reply #72 on: 19 November 2012, 13:19:06 »
Update on where are have got to now.
received all the laser cutting back, this is most of it as i have used the diff parts.
Stainless exhaust flanges came out nice, not sure what pattern i will use yet, but both types match up perfect with the head/gaskets
I had marked the front brace position with the diff in, then welded in the front brace with some addition over gussets for added strength and to minimize any tendency to 'twist'.
here on in it got fiddley, i had to position the diff back in, on all the new brackets i had lasered, level the car, level the diff and then centralise. took a while with a few laser guides and inclinometers but got there. I have only tacked the front supports in and one seam weld on the rear hanger. i have also tacked 2 trianglulation pieces in, and will also fit two vertical drops to the rear to stop that twisting in the chassis.
i am a bit paranoid about the twisting as i watched a kit car programme the other day where the chassis twisted at the rear due to a non standard engine and diff being used (not this kit). so i am over egging things a little, but it should be capable of taking alot of punishment now
i will remove the diff tonite and carry on welding it all in so its all at full strength.
2woody
  • Northumberland
« Reply #73 on: 19 November 2012, 14:15:22 »
what are the hoses for ? has it got a cooling pump ?
markrnorton
  • Essex
« Reply #74 on: 19 November 2012, 15:04:29 »
yes, it runs a diff cooler as standard (nissan S14/skyline)
not sure i'll run one yet, i'll wait to see what goes on.
also has a speed sensor in the front and temp sensor at rear
Pages: 1 2 3 4 [5] 6   Go Up
