Pages: 1 [2] 3  All   Go Down
Author Topic: what lpg systrm is best at the moment?  (Read 12670 times)
Re: what lpg systrm is best at the moment?
« Reply #15 on: 31 August 2012, 10:55:01 »
Both mine were sub £600, complete with everything, and another £100 for the safety test/certification. I obviously use cylinder tanks in my saloon, which are cheaper.
As LD says, the most successful Stag setup we've found so far is AC Stag 300 plus ECU, KME gold vapouriser and AC injectors drilled to 2.2mm.  Some of the other Stag variations suffer a lag on autos during redline gear changes. Tunnie has a Stag on his 2.2, bought from some ebay seller, and its shite, simply because the other components cannot manage the required flow. Anything over about 4k rpm, and its clearly grumpy, before it gives up and flicks back to petrol.
Not sure how much of the 'known good' AC Stag/KME Gold setup Teilo can still get. He is also really hard to get hold of - don't bother emailing or leaving messages with the (virtual) reception, you need to keep trying, and physically speak to him.
« Reply #16 on: 31 August 2012, 11:28:00 »
As I told him when we fitted it, and we told him when we calibrated it. Fortunately with Tunnie's driving style 4k RPM is way more than it ever sees ::)
He still has most of it, although how long for I don't know. He's moving across to a different brand which he says is good :-\
As for contacting him, I have given different details out this time as the virtual reception and number associated with it no longer exist ;) Once you manage to speak to him he's normally quite good, but not always ::)
« Reply #17 on: 31 August 2012, 11:30:10 »
Except when he makes me drive it, as a punishment  :'(
« Reply #18 on: 31 August 2012, 12:04:00 »
Your safe for now its untaxed and no MOT. But my trusty steed will ride again soon  :)
Y26SE
  • Spalding
    • 2002 Omega 2.2 DTI saloon
« Reply #19 on: 31 August 2012, 19:21:53 »
blimey, the setup can be quite hit and miss then.  :-\
What is this FUEL ECONOMY you speak of, it is alien to me.
Not now i have a dti: Omega ownership without the petrol station bite. JUST GARAGES INSTEAD
« Reply #20 on: 31 August 2012, 19:23:58 »
With the right components it's fine ;)
Y26SE
  • Spalding
« Reply #21 on: 31 August 2012, 21:17:09 »
ok so if i start getting resources together with the Stag setup you have found so far and as described above and if i cant get anywhere with the telio route should i start asking lpg companies for the AC Stag 300 plus ECU, KME gold vapouriser and AC injectors ect and ill go for range as well so ill lift the floor to get the larger tank in :)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #22 on: 01 September 2012, 02:03:13 »
mines got a prinns vsi system on it and even that suffers lag on the redline, if giving large have to back off when close to it to let it select next gear then boot again, ive got used to it now but is a good system and never given any other bother in past 15k miles
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #23 on: 01 September 2012, 08:48:59 »
I wouldn't expect that of a Prins system, if it was installed and setup properly :-\
« Reply #24 on: 01 September 2012, 09:24:30 »
Yes take it back and tell them to sort it. Has it always had the problem? Or did It gradually creep in gradually?
« Reply #25 on: 01 September 2012, 21:36:16 »
As said, that's not right!  :-\  Mine's a Prins system and you can't tell the difference between petrol and LPG!  :) and incidently has done about 165,000 miles since conversion!  :y
adey2
« Reply #26 on: 03 September 2012, 14:08:46 »
was on the car when i bought it, got all the paperwork from installers
Y26SE
  • Spalding
« Reply #27 on: 03 September 2012, 21:22:43 »
Can anyone substantiate wether lack of lubrication from the lpg as a fuel will half the life of the engine
« Reply #28 on: 03 September 2012, 21:31:18 »
The GM V6 engines do not need flashlube
« Reply #29 on: 03 September 2012, 23:15:20 »
As said mine's done 165,000 miles since conversion at 50,000 and still going strong!  :)
Pages: 1 [2] 3  All   Go Up
