Author Topic: LPG issue  (Read 2434 times)
LPG issue
« on: 31 August 2012, 12:44:08 »
3.2 V6
I am running Stag 300, with dual output KME gold and fast flow Magic Jet injectors. Pulls to the red line with no issues at all.
Since converting to manual, I am noticing that at idle, it's revving to high. It will often just sit at 1500 to 2000 rpm in neutral.
If you switch to petrol, after a short while it doesn't do it at all, at any time. On gas - it does.
I've been through and checked there are absolutely no air leaks.
The pressure is 1.05 bar and nozzle size is 2.5mm. Fuel maps ok.
Any advice would be much appreciated!
I also get fuel trim bank 2 code quite a lot.
I suspect this has always been a problem, but wasn't really noticible with the auto transmission, which would have just swallowed up those revs.
Any suggestions? :y
Re: LPG issue
« Reply #1 on: 31 August 2012, 12:53:46 »
Cant think of any reason for it to do it on LPG and not on petrol... After all, it's the petrol ecu that's controlling it :-\ :-\
Have you done a full calibration since converting to manual? ???
Re: LPG issue
« Reply #2 on: 31 August 2012, 12:54:35 »
What are the trims doing at idle on LPG (may need to watch them for 15mins or so).
Suspect the map is out at idle
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: LPG issue
« Reply #3 on: 31 August 2012, 13:01:21 »
My 3.2 LPG Manual (although never was an Auto) did something similar a few months back, pulled off the Motorway from a long run and noticed it was idling high about 1300rpm but was fine on petrol, did a few times over the next day or so after a longish run.
I dissed the battery over night and run of petrol for a day or so, its been fine on LPG ever since (apart from another recent problem which is not related), so might be worth a shot give the main ECU a reset with battery off.
Chris.
« Last Edit: 31 August 2012, 13:04:09 by zirk »
Re: LPG issue
« Reply #4 on: 31 August 2012, 13:08:40 »
I have seen manual DBW cars do this when the MAF is out, so I would agree that a mixture issue might also do it. As said, fuel trims would be interesting.
Re: LPG issue
« Reply #5 on: 31 August 2012, 13:24:46 »
Is 2.5 nozzle size not too big, btw?
Re: LPG issue
« Reply #6 on: 31 August 2012, 13:26:50 »
Don't know with those Magic injectors ;)
Re: LPG issue
« Reply #7 on: 31 August 2012, 13:30:49 »
Yep all calibrated etc. Lines overlay each other perfectly.
Didn't start calibration, or gather the petrol curve, until it had run on petrol for 500 miles and trims were solid.. I then mapped it.
Took minimal adjustments..
Re: LPG issue
« Reply #8 on: 31 August 2012, 13:43:14 »
Check codes and trims then... Pay attention to the trims at idle on both fuels.
Does it do it all the time or only occasionally? Under what circumstances/Can you replicate it?
Re: LPG issue
« Reply #9 on: 31 August 2012, 14:04:23 »
Might also be worth checking the MAF output at hot idle, everything turned off. typically 12Kg/h or so.
Page created in 0.024 seconds with 20 queries.
