Author Topic: Am I losing fuel?  (Read 4494 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Am I losing fuel?
« on: 07 September 2012, 09:47:27 »
Hi guys,
2000 Omega 2.5 V6.
Noticed this a little while ago. The fuel gauge seems to be dropping real quick. Example: last night I filled up and had just over half a tank. when I drove to College this morning my fuel gauge was just over half a tank so thats fine. I then noticed that about 2 miles down the road that it had dropped to just below half. I checked the trip computer and I watched the range full very rapidly during this morning's journey: started at 215 and kept dropping. but then it's now seemed to slow down around the 165-170 mark. now my trip involves a dual carriage way trip and in the past as soon as it gets on a motorway or national limit road the range starts to increase. but again it kept falling.
i've had a look uner the car while it was running and there are no visible leaks at all. is it worth popping a spark plug out to see if its soaked with fuel?
any ideas?
cheers
RIP Paul Lovejoy
Re: Am I losing fuel?
« Reply #1 on: 07 September 2012, 09:50:03 »
Remember that the trip computer takes an average over the last x miles (15 or so I think) for it's calculations... I can easily take 100 miles off the range in just a few if I come from a sensible cruise to blatting around the twisties ;)
Webby the Bear
  • Northampton
« Reply #2 on: 07 September 2012, 09:51:52 »
cheers LD.
Yeah to be honest it wasnt so much that that bothered me. it was the drop over a very short distance on the fuel gauge. i certainly can't see any leaks or smell petrol anywhere.
RIP Paul Lovejoy
« Reply #3 on: 07 September 2012, 11:36:44 »
Petrol will evapourate quickly when it leaks.
If your journeys are now shorter, expect to use more, but if its a sudden drop in MPG, and nothing has really changed, I think you need to investigate further.
The MID is not a good test for this, but the gauge should be.
I went out yesterday lunchtime for LPG - it was pretty damn empty, the (petrol) range started at about 420m (yeah, its got the wrong config on the GID, and I can't be bothered to reconfig it ::)), and by the time I'd filled up (bearing in mind I'd used little petrol, as mostly on gas), it was 220m range...
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #4 on: 07 September 2012, 12:32:39 »
Sounds normal to me . . .  ???
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Webby the Bear
  • Northampton
« Reply #5 on: 07 September 2012, 14:19:23 »
Thanks guys,
TB, yeah it's exactly that... we're used to low MPG as we do short trips but this is a ''noticeable'' drop of the range AND on the petrol gauge.
Sorry what is MID and what tests could I conduct to isolate a leak? :) If it does have a leak and it's in the injection area at least I have a spare fuel rail :)
RIP Paul Lovejoy
« Reply #6 on: 07 September 2012, 14:22:24 »
Can you smell petrol inside the car when your driving  :-\
« Reply #7 on: 07 September 2012, 14:33:03 »
MID is the screen above centre airvents
Webby the Bear
  • Northampton
« Reply #8 on: 07 September 2012, 18:15:11 »
cheers guys. nope ive already tried to sniff for petrol and nothing. as said ill pull a plug out, check it for being soaked. ill recheck for visible leaks and check the fuel filter too.
anything else i can do?  :-\
RIP Paul Lovejoy
« Reply #9 on: 07 September 2012, 18:20:15 »
Be interesting to see if the trims have gone haywire. Passing Brackley soon?
thebaldeagle
  • chester
    • Omega MV6
« Reply #10 on: 07 September 2012, 18:52:01 »
our mv6 was loosing fuel alarmingly ..turns out the "new" fuel filter we fitted had a leak on the seam...could be worth while checking that?
« Reply #11 on: 07 September 2012, 19:32:45 »
What does that mean ?  :)
Webby the Bear
  • Northampton
« Reply #12 on: 07 September 2012, 21:55:02 »
cheers guys. Yeah ill definitely be checking the fuel filter. Sorry TB what seems? I'm actually up your way in October for the silver stone BTCC. 29 quid for a day ticket :-) cant wait :-)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #13 on: 07 September 2012, 21:55:43 »
edit. Trims not seems. Sorry lol
RIP Paul Lovejoy
« Reply #14 on: 07 September 2012, 22:07:53 »
