Author Topic: cutting out  (Read 4817 times)
Andyv6
  • westmidlands
    • Elite 3.0, Vectra b3.0l
cutting out
« on: 11 September 2012, 19:39:40 »
Any ideas guys, elite Auto 3.0l 1998 cuts out intermitant at idle or when changing into reverse, crank sensor replaced with genuine gm part, was ok for a bit then started cutting out again, cleaned out all breather system, again was ok for a few days then cutting out again, also idle valve replaced ok for a few days then same again, only fault code stored every time was speed sensor, any help guys this thing is causing me brain ache now lol.
Re: cutting out
« Reply #1 on: 11 September 2012, 21:43:05 »
Speed sponsor...? Abs? Crank? Cam? Is there one in the auto box? :-\
What was the exact code?
Re: cutting out
« Reply #2 on: 12 September 2012, 00:21:26 »
Assume you mean crank sensor mate - code 19.  Ignore the unhelpful sarcasm above  ::)
Don't assume because its a genuine Vx crank sensor that its ok - I had a new Vx one pack up within a month of fitting - a replacement is (as far as I know) still working over 18 months later (believe thats true Al?)
Re: cutting out
« Reply #3 on: 12 September 2012, 00:47:49 »
Approx.£122 on TC. £158 retil. :y
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
Re: cutting out
« Reply #4 on: 12 September 2012, 09:47:14 »
If indeed it is the crank sensor code, hopefully you will achieve a replacement FOC? Bit of a nuisance if you've fitted the replacement yourself...you may be going through it again. Are the connections clean and sound? Replacing it should confirm (if code confirms fault). Just to cheer you up, or for a laugh, when my c/s failed, purely by coincidence, I was parked in the VX Dealer car park, picking up parts, wouldn't start can you believe it, drove in, can't drive out! With no AA/RAC recovery etc I paid them to replace it...short of towing it away, was my most cost effective option! No wonder they are in business, it lands on their doorstep!!! Best of luck sorting it.
Re: cutting out
« Reply #5 on: 12 September 2012, 09:54:11 »
Have you replied to the wrong thread again Albs? ???
Not sure why you constantly have to "pick at the scab" so to speak. A valid question IMO, could be any of several speed sensors ;) I'v always been told not to assume as it could make an Ass out of U and ME ;)
Admittedly it's likely to be a code 19 for crank sensor but the OP needs to confirm that before going any further ;) The fault could equally be a split in the ICV pipework ;)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: cutting out
« Reply #6 on: 12 September 2012, 10:05:53 »
Hi Andy, welcome first of all too the Forum. :y
In the maintainence section there is a how too so you can read your codes which will be stored on the cars ecu.
First thing is to read them, to see if things are made easier by stored codes.
Come back on here with your find
Daz  :y
Re: cutting out
« Reply #7 on: 12 September 2012, 11:59:06 »
appologies if this reads other than factual, intended as a bump really, as it was half way down the page with no replys. But as bumping is not allowed I thought elaborate a little. If a bit abruptly.
Exact code would be good though, no?
Andyv6
  • westmidlands
Re: cutting out
« Reply #8 on: 12 September 2012, 12:29:53 »
Yes guys it is fault code 19 confirmed by snapon scanner and paperclip test, the crank sensor failed on its way to MOT last year and was replaced with a cheap after market one that made the car run, but didn't sound right, this was replaced under warranty, then the car would not run with the new replacement, a genuine one was fitted that actually cost less than the aftermarket and it ran sweet as a nut, some times it will splutter a little then die other times it just dies.
« Last Edit: 12 September 2012, 12:33:34 by Andyv6 »
Re: cutting out
« Reply #9 on: 12 September 2012, 14:40:11 »
Not much luck then :(
If the wiring and connector are good and no filings on the magnetic end of the sensor I guess that just leaves .... yet another sensor ...? :-\
Re: cutting out
« Reply #10 on: 12 September 2012, 20:05:11 »
Agreed - was comenting on the statement "Is there one in the auto box?"
After all the op is a newbie and I felt any comment on his topic could have been more constructive and helpful ;)
At the end of the day sounds like the op has a dodgy/incorrect crank sensor ;)
Andyv6
  • westmidlands
Re: cutting out
« Reply #11 on: 18 September 2012, 14:01:27 »
Had another look at this this weekend while replacing abs ecu, checked wiring from sensor plug back to ecu all ok,checked resistance of sensor all ok and when cranking had steady voltage, even changed sensor for another and still the same.
Re: cutting out
« Reply #12 on: 18 September 2012, 18:32:35 »
Hmmm, having a 19 still means there is a problem with the ECU properly seeing the signal from the crank sensor.
Was this the speed signal you meant in first post, as I don't think the 3.0l engine management unit gets a direct speed signal.
Is 19 the only code in the engine management ECU? Out of interest, did you get the gearbox and ABS codes read, if so, any codes?
Sorry for all the Qs  :-[
Andyv6
  • westmidlands
Re: cutting out
« Reply #13 on: 18 September 2012, 21:56:49 »
The only other code in there was incorrect rpm signal, no faults stored in auto box and abs could not talk to due to being faulty tc and abs lights coming on intermitantly and losing speedo.
duke101
  • lincoln
    • Omega Estate 2.5 V6
Re: cutting out
« Reply #14 on: 19 September 2012, 06:29:48 »
These are caused by a faulty ABS ECU
Page created in 0.024 seconds with 20 queries.
