Author Topic: turbo trouble  (Read 2679 times)
phillswfc
  • Pontefract
    • 2.2Dti CD Omega
turbo trouble
« on: 11 September 2012, 21:20:55 »
I have a 2002 2.2Dti and my turbo seems a bit off. When i accelerate, the turbo kicks in and i get the extra power you would expect but then it dies for a second before returning?? Once the initial boost and loss has gone i get a smooth power boost through the rev range, it's as though the turbo has 2 phases.
twiglet
  • Norwich, Norfolk
Re: turbo trouble
« Reply #1 on: 11 September 2012, 21:22:38 »
Does you engine management light come on at all mate?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: turbo trouble
« Reply #2 on: 11 September 2012, 21:28:57 »
Good starting point but be aware if 0400 (E.G.R.) crops up then could just be leaky vacuum pipes...
waspy
Re: turbo trouble
« Reply #3 on: 11 September 2012, 21:36:27 »
It could be that the turbo's over boosting & the ECU recognises this & shuts the boost off a little. Do you know if the car's been re-mapped?
phillswfc
  • Pontefract
    • 2.2Dti CD Omega
Re: turbo trouble
« Reply #4 on: 11 September 2012, 21:36:55 »
It comes on on the overun, but only if i've been coasting a few hundred yards or more. The engine does sometimes judder when i'm hovering around the 1500rpm mark where the turbo kicks in. It's as if the turbo can't make it's mind up what to do.
phillswfc
  • Pontefract
    • 2.2Dti CD Omega
Re: turbo trouble
« Reply #5 on: 11 September 2012, 21:38:43 »
as far as i'm aware it hasn't been re-mapped
waspy
Re: turbo trouble
« Reply #6 on: 11 September 2012, 21:43:45 »
Does it only happen when you give it full throttle? Like foot to the floor.
phillswfc
  • Pontefract
    • 2.2Dti CD Omega
Re: turbo trouble
« Reply #7 on: 11 September 2012, 21:47:08 »
yes, only on full throttle
waspy
Re: turbo trouble
« Reply #8 on: 12 September 2012, 17:11:40 »
The turbo's over boosting. Re-mapping usually causes this issue. How long have you had the car? The reason I ask is, if you're used to driving a petrol & you'll floor the throttle for more power. With the DTi there will be a a sweet spot that you'll get full power with & it's not flooring the throttle. Find the sweet spot :y :y
Omegatoy
  • UK
Re: turbo trouble
« Reply #9 on: 12 September 2012, 18:44:15 »
could also be a sticky wastegate? when the wastegate catches up wth the boost it vents off then returns to normal? worth cleaning it or at least checking its operating freely!
Y26SE
  • Spalding
    • 2002 Omega 2.2 DTI saloon
Re: turbo trouble
« Reply #10 on: 12 September 2012, 20:19:08 »
i had a dti Vectra a while back it suffered intermittent power and it was a combination of a leaking vacuum hose but this only happens if i was giving it beans and i replaced the split pipe but i believed my waste gate was also a bit grumpy so i stuck a boost gauge in and i had boost at various pressures when i had my foot down then off and then on the next press of the throttle i had more boost and power then again on removal and reapply the power was down a bit and so was the boost. i ended up getting a second hand turbo and replaced all the L joints and straight connectors on my vacuum system all was well again.
What is this FUEL ECONOMY you speak of, it is alien to me.
Not now i have a dti: Omega ownership without the petrol station bite. JUST GARAGES INSTEAD
phillswfc
  • Pontefract
    • 2.2Dti CD Omega
Re: turbo trouble
« Reply #11 on: 12 September 2012, 21:25:55 »
thanks for the suggestions, i shall check them out over the weekend and see if i can cure it.
Re: turbo trouble
« Reply #12 on: 12 September 2012, 21:35:47 »
Check vac hoses and clean the manifold pressure sensor.
Also seen this when the swirl flaps are sticking and need cleaning
Page created in 0.022 seconds with 20 queries.
