Author Topic: Replacing balljoint boots.  (Read 2347 times)
« on: 13 September 2012, 14:14:01 »
Got a couple split (inner end of both tierods),have replacement boots to fit,but cant get the bloody things on. Or to be more exact I can get them on without the retaining springclip,but cant work out how to fit that.
Anyone done it,I assume theres some knack,technique or maybe a tool ?  :-\
A minor job I know,but proving to be a pita at the moment. :(
Re: Replacing balljoint boots.
« Reply #1 on: 13 September 2012, 18:38:46 »
Numerous ways. Put the clip on the boot then fit the boot, with a twist on action like your screwing on a bottle top. Or fit the boot then work the clip on from one end while working it on a bit at a time. Bit like a key ring. Ah, are you one of these people that bites their nails?
« Reply #2 on: 13 September 2012, 22:02:04 »
The keyring method works well with a slender flat head screwdriver :y
Take your time though, quite easy to skewer either your hand or the new gaiter ::)  :-X
« Reply #3 on: 13 September 2012, 22:57:35 »
Do you reckon he's done it yet?
« Reply #4 on: 13 September 2012, 23:20:23 »
Probably trying to work out how to dial 999 with a screwdriver through one hand and the other holding some bog roll over the hole to stem the bleeding ::)
« Reply #5 on: 13 September 2012, 23:25:31 »
You obviously know me.If theres an accident to be had I will have it. ::) ;D
Will try the methods suggested thanks.Have been attempting to do it with the other end still attached at the hub.Might take them off the car and bring them to work tomorrow night and put them in the vice and then give it a go. :y
« Reply #6 on: 14 September 2012, 00:06:03 »
It's easy enough :y just take your time. Just done a couple on a new droplink :-X quite a satisfying little job 8)
« Reply #7 on: 14 September 2012, 19:41:33 »
If it's easier, I don't see why you couldn't use thin cable ties :-\ presumably the idea is simply that the boots are secure and dirt/moisture proof :y
« Reply #8 on: 14 September 2012, 20:21:59 »
That had crossed my mind tbh Al.I might just give it a go. Busy at work,but got a few hours off tomorrow so will have a fiddle and see if I can get it sorted. :y
« Reply #9 on: 14 September 2012, 20:52:51 »
That`s gotta be a bloody first ;D
« Reply #10 on: 14 September 2012, 21:00:37 »
Well, I say busy,I have to spend a lot of hours here at the moment. :D
« Reply #11 on: 14 September 2012, 21:01:33 »
Only thing busy is "fat fingers" :P ::)
« Reply #12 on: 14 September 2012, 21:03:41 »
yep. :P  ;D
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #13 on: 14 September 2012, 21:11:48 »
Deja Vu was just trying exactly that about an hour ago, wasted more time trying to put it on than it took to remove the part. Decided just to opt for the easy option. CABLE TIE.
