Author Topic: v6's alternator  (Read 3946 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
v6's alternator
« on: 13 September 2012, 18:44:06 »
Did the 3ltr engines all have the same bosch alternator ?
If so, has anybody got the part number for the regulator please ?
Mines fluctuating between 12 and 13.4 volts max so I'd say its time for a change  :(
Re: v6's alternator
« Reply #1 on: 13 September 2012, 18:52:45 »
I think Dbug has just been through the alternator replacement job. Believe he went through the vx exchange scheme. Cheaper and they can give you the right one from the car reg, unlike a factors.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #2 on: 13 September 2012, 18:58:09 »
It spins ok with no bearing noises so i'm just trying to keep the price down by replacing the slip ring and regulator myself chris  :-\
Thanks anyway  :)
I_want_an_Omega
Re: v6's alternator
« Reply #3 on: 13 September 2012, 19:01:03 »
Thanks anyway  :)
Isn't that a job for an electrician  ;D ;D ;D - gets coat ................
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #4 on: 13 September 2012, 19:02:38 »
Thanks anyway  :)
Shut it tubby  ;D ;D ;D :D :D :D
Re: v6's alternator
« Reply #5 on: 13 September 2012, 19:31:46 »
Have you checked the crimps on the battery terminals first ;)
  • Auckland
    • Mazda MPV
Re: v6's alternator
« Reply #6 on: 13 September 2012, 19:46:44 »
I fitted a new regulator to my alternator a couple of months ago. I think it would have been £30 for a genuine Bosch one or £20 for a pattern part.
A local old-school alternator repair shop had a pattern regulator in stock so that is what I fitted.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #7 on: 13 September 2012, 19:54:13 »
Battery terminal crimps are ok  :y
I'll check the alternator one tomorrow when I jack the car up  :y
The lpg is starting to throw up more low voltage faults and the abs/tc had a "low voltage telltail" fault last week  :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #8 on: 13 September 2012, 19:55:07 »
Have you got a part number handy ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #9 on: 13 September 2012, 20:00:47 »
Slightly off the topic but what is the nominal voltage that the stag lpg controller is setup for ?
Is that set during initial calibration ?
If so, am I right in thinking that if the calibration was setup with a voltage of 14.5 ish then I loose 1 volt its going to throw up this fault  :-\
  • Auckland
    • Mazda MPV
Re: v6's alternator
« Reply #10 on: 13 September 2012, 20:20:53 »
Have a read through this thread http://www.omegaowners.com/forum/YaBB.pl?num=1289737894
There are some links to part numbers at the end but I think you have the earlier alternator :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: v6's alternator
« Reply #11 on: 13 September 2012, 20:26:01 »
I'll have a nosey
My lump is out of a 99 mfl  :-\
Re: v6's alternator
« Reply #12 on: 13 September 2012, 20:32:31 »
Yep - picking up replacement alternator tomorrow - £100 + vat (trade price).
My stealer is quite good - ordered it without payment, supplying it without exchange unit or deposit.  Relying on me to bring old unit in.
Looking to swap it tomorrow pm - car 2.6V6 F/L Estate.
Its a 120amp unit fitted to 2.6 and 3.2 engines.
Will let you know how easy( ::)) it was to swap ;)
« Last Edit: 13 September 2012, 20:46:35 by dbug »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: v6's alternator
« Reply #13 on: 13 September 2012, 21:52:47 »
one bolts a bit of a git, and done by feel and a lot of swearing ::)
Jaguar XJ6
Re: v6's alternator
« Reply #14 on: 13 September 2012, 22:13:50 »
I do remember some swearing, if little else.
