Ford Sierra overheating
Started by Steve Brookman, 13 September 2012, 18:47:16
Just a thought, but have you tried flushing the heater matrix, radiator and engine separately  :-\
Steve Brookman
Thats the next thing to do, but heater was working very well until temp rose.
Noticed as well that the car seemed to missing on tickover-suspecting a possible head gasket as well.
Cheers Steve
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
If that the case suspect a crack between 3 and 4 :'(
Steve Brookman
Thanks
Friend having a look on Wednesday.
Steve
Previous
Sorry :'(
Have had 2 2.0 twin cam Granadas in the family, both suffered head failure at about 120k, and both failed in an almost identical way...  :-\
Fingers crossed for better news :y
Steve Brookman
Thanks
Has been in the family for 13 years so will be repaired whatever is wrong, only thing that has gone wrong in 13 years apart from a torque convertor seal which cost me £140 to have fixed 10 years ago. Bodywork is excellent for the year and it's usually quite good on fuel, though I have noticed an increase revently perhaps due to the HG.
Thanks
Steve
Previous
Hopefully you'll see another 13 years out of it :y It's obviously a Cologne built one 8), they do seem to be a bit more rust resistant than the Ghent ones :y
Steve Brookman
Quick update.
Had sniff test done-HG okay.
Changed engine fan sensor and temp guage sensor.
Still going way up when pootling around-on a run it's around 3 o'clock.
Had it ticking over in work - drivers side fan came on when gauge was nearly on the red-but I could still hold the top hose for quite a while.
Borrowed a infra red thermometer from work. When we got home and the guage was way up-the top hose was around 75 degrees and the bottom hose 85 - 90 degrees. The fan then came in.
It doesn't seem to be overheating but when it's up high on the guage-the heaters blow cold.
Will flush heater matrix this weekend.
Cheers
Steve
Previous
Good news :y
Hopefully a flush will cure it, I don't envy you the task of changing it if it's shot :-\
Steve Brookman
Thanks Al,
I hope it's not completely shot-I sometimnes hear a swishing noise so am hoping there is air in it.
Will have a look tomorrow!
Cheers
Steve
Previous
