Author Topic: DEX III, Is this ok?  (Read 2572 times)
D
  • SE London
    • 03 3.2 Elite
« on: 15 September 2012, 15:46:18 »
Thanks to a friendly OOFer who will help top up my ATF tomorrow. However due to my superb planning skills, I have not sourced any Fuchs 4000. So is this ok as it is reasonably priced and easily available.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_175466_langId_-1_categoryId_255219
Or avoid and get the Comma alternative?
All recommendations welcome.
Re: DEX III, Is this ok?
« Reply #2 on: 15 September 2012, 16:03:48 »
You'll need to physically check what's written on the bottle :y
The VX oil is given as 19 40 763, so would expect to see that somewhere in the small print :y also the owners manaual should give the spec needed, again expect to see that on the bottle :y
Potentially you could need 9 litres of the stuff :-\, and lots of shampoo for afterwards ;D
My understanding is that Dexron III is Dexron III regardless of the bottle it comes in :-\, but double check the small print on the bottle before buying :y
D
  • SE London
    • 03 3.2 Elite
« Reply #3 on: 15 September 2012, 16:04:42 »
Yes Tunnie. That would be my first choice. However unless Opie did Sunday deliveries, I dont think I can use them for an ATF top up that we are going to do tomorrow. Hence looking at alternatives. My fault for not being organised.
D
  • SE London
    • 03 3.2 Elite
« Reply #4 on: 15 September 2012, 16:07:40 »
Yes, my understanding is that Dex III is a GM spec that manufacturers comply with. I would normally go for it, just a bit wary given the rep that Castrol have on OOF with regards to engine oil.
Dont need 9L. Its just a top up.
« Reply #5 on: 15 September 2012, 16:21:17 »
 :y better to have enough rather than get stuck in and run out ::)
I used to use the Castrol one to top up my auto Granadas, never did a fluid change on them though :-\ they used to leak it quickly enough to keep fresh ;D
« Reply #6 on: 15 September 2012, 16:37:27 »
Comma is OK for a top up
steve6367
« Reply #7 on: 15 September 2012, 17:36:22 »
Have used that in mine without any problems that I know of. I seems to match to required spec.
Steve
« Reply #8 on: 16 September 2012, 09:11:20 »
I try to use Fuch Titan 4000, but use Coma in emergencys.  Maybe placebo effect, but I reckon the Fuch makes it feel smoother.
Although, as they are similar priced, worth it, even if placebo effect only
D
  • SE London
    • 03 3.2 Elite
« Reply #9 on: 20 September 2012, 17:03:41 »
Update. Used the Castrol Dex III. Issues with gearbox have resolved completely. Seems to be a reasonably priced option if like me you plan things poorly.  :-[
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #10 on: 20 September 2012, 17:07:23 »
Glad it's sorted it out D.
D
  • SE London
    • 03 3.2 Elite
« Reply #11 on: 20 September 2012, 18:08:23 »
Yes. Thanks for your help sorting it out.  :y
