Author Topic: Gearbox woes  (Read 1547 times)
SMD
  • London
    • :( nowt
Gearbox woes
« on: 15 September 2012, 17:42:25 »
Noticed for a while but wanted to be sure.
Driving along at 20mph and lift the throttle, get a thumping sound. Car is 3.2. Software is version 8 and oil, although not checked, was last topped up in May and no signs of leaks.
I hate cars  >:(
Re: Gearbox woes
« Reply #1 on: 15 September 2012, 17:44:41 »
Is this something new or has it always done it?
Mine has a range of speeds around 20MPH where it makes a jerky change if you lift off. Could be the case that they all do it.
SMD
  • London
    • :( nowt
Re: Gearbox woes
« Reply #2 on: 15 September 2012, 18:57:07 »
Think its new, noticed it 2 weeks ago. Mileage is 48.5k
Hopefully Kevin its something normal on these cars  ;D
Marie
    • 2ltr LPG Estate
Re: Gearbox woes
« Reply #3 on: 15 September 2012, 19:13:49 »
Ours does the same around 20 mph too.
Re: Gearbox woes
« Reply #4 on: 15 September 2012, 20:05:25 »
I can't believe it's got mechanical problems at that mileage.
Could it be a "feature" of the new gearbox firmware? That's only been done a month or two, after all?
SMD
  • London
    • :( nowt
Re: Gearbox woes
« Reply #5 on: 15 September 2012, 20:15:03 »
You could be right, I wonder if others can confirm.
I remember a while ago a member here called 'bigmecube' had his gearbox updated along with fluid changed and then reported thumping at 20mph
Page created in 0.022 seconds with 20 queries.
