Another year
Started by RobG, 17 September 2012, 17:43:06
Fast idle CO was on the limit (0.20) :o but a pass is a pass 8)
Quote from: RobG on 17 September 2012, 19:55:59
Absokinglutely :y
bored bigyin54
#17
Quote from: Albitz on 17 September 2012, 19:46:28
Quote from: bigyin54 on 17 September 2012, 17:56:51
good apart for cant get front nearside wheel off to change brake pads grrrr :y and i think i need a track rod now :y :y
That will be those pattern wheel nuts Ralf. ;) ;D ;D
always albert  ;D ;D and its those vx wheels thats the cause ;D ;D
PAULCDX
Well done Rob, well pleased for you  :y
Quote from: bigyin54 on 17 September 2012, 23:17:08
Put some pattern Carlos Fandango super wides on there Ralf. :y :P ;D
Webby the Bear
;D ;D ;D ;D ;D
RIP Paul Lovejoy
Little bit of copper slip stops them sticking, took old wheels of my 2.2, which had not moved for 8 months, no issues.  :)  :y
bored bigyin54
Quote from: RobG on 17 September 2012, 17:58:56
Loosen the bolts and drive it a few yards then dive on the brakes
well rob that didn't work . still stuck .
Quote from: bigyin54 on 18 September 2012, 18:34:34
Try it going a little faster, it must work because nothing is holding the wheel to the hub  :y
bored bigyin54
Quote from: tunnie on 18 September 2012, 18:38:29
done it  at 30 mph did not shift it >:( >:(
Trolley jack, axle stand, bolts out, block of timber, short handled "Sammy"
bored bigyin54
Quote from: RobG on 18 September 2012, 18:42:32
whats a sammy  ??? ???
Quote from: bigyin54 on 18 September 2012, 18:45:40
Sledgehammer  :y
