LPG Injector Q
Started by 05omegav6, 20 September 2012, 10:06:48
Ah, LD.. Speaking of reducers - Teilo was suggesting an AC reducer, unless I'd specifically like the KME he's supplied to you guys before.. any thoughts?
Will find out tomorrow when it's delivered :-\
Still need to source a tank and the bits for the rear end kit :y
Thank you for the offer, not sure when the car will be ready for fitting, but plan to have everything in place ready :y
Who is the prefered tank supplier? Was thinking Tinley Tech :-\
tigers_gonads
I maybe wrong here but I thought it was the KME Gold's that was rated at 280 bhp ?
Quote from: aaronjb on 20 September 2012, 22:13:52
Depends if you are willing to be a guinea pig ;)
Quote from: taxi al on 20 September 2012, 22:23:29
Tinley are very good but also very expensive. What tank are you going for?
Another company are FES (I think :-\), I've got contact details somewhere
Thinking: 4-hole Full-Toroidal Tank 720x250 mm 82litres +V&B £279.00 if it fits :-\ been meaning to measure up the spare wheel well for the last week ::)
650mm diameter is the largest that fits ;)
I went 650x270, 76L GZWM tank and Stako valve box so it doesn't need too much modification :y
Oh, and that seems a bit pricey to me :-\
One of these: 4-hole Full-Toroidal Tank 650x270 mm 76litres +V&B £246.70?
Quote from: taxi al on 20 September 2012, 23:13:01
Yep, but it must be a Stako valve box. It's a different shape ;) or the valve box needs modifying ;)
Still seems pricey unless it includes all the pipework :-\
Stako is one of the two choices of valve box, does include the valves and box, but not the sender unit :-\
Not ideal, being used and all :-\ personally I would prefer to fit a new tank rather than chance an old one :-\
Right, kit arrived this morning :y includes the programming disc and interface cable, wiring diagram and guarantee book... the wiring loom and associated parts are all clearly Autogaz AC. The loom is clearly a 6pot one :y
The injectors are Dream XXI SL. My only immediate concern is that they've sent me 2 rails of  4 injectors :-\
At risk of asking a stupid question, is this a problem?
tigers_gonads
Nope  :)
Just plug 3 in on each side  :y
