Author Topic: CD PLAYER IN SAFE MODE  (Read 2942 times)
mowerman71
  • essex
  • go baby go
« on: 20 September 2012, 20:50:07 »
radio works fine , but cd player has never worked, the 4 disc cassette loads but nothing , is it a code thing , or is it broke ???? any ideas, just says on the display CD SAFE.
Re: CD PLAYER IN SAFE MODE
« Reply #1 on: 20 September 2012, 20:53:10 »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 21 September 2012, 07:41:08 »
Thanks RobG for the link   :y
However, the link posted is for the common failure of the software on the CCR2006 which gives CDC SAFE whereas your message of CD SAFE would suggest that you have an external changer looking for a code?
It may help if we knew what make and model of stereo you were referring to?
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #3 on: 21 September 2012, 08:43:38 »
OP mentioned 4-disc cassette so assumed it was the CCR2006 :-\
« Reply #4 on: 21 September 2012, 09:46:16 »
CDC as in ccr2006 can be fixed by Dave DND.
CD Changer as fitted to CCR600/800 needs its own code, and follow the code entry procedure. Though the 4 disk changer was never a factory fit to Omega ccr600/800, only Vectras/Astras etc
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 21 September 2012, 12:10:26 »
I wasn`t sure as the external 4 disc changer (CDC3) can give similar fault
Not sure if they were fitted to Omega`s though
Might be worth checking that error message again for CD or CDC
« Reply #6 on: 21 September 2012, 13:44:27 »
The CDC3 fitted to CCR600 etc in Vectra-Bs and Astra-Gs has its own unique code, similar to the CDC2 setup with CCR600. Never seen one of those suffer any other problems other than the usual lasers and jammed mechs, but I don't see that many, as they were never Omega factory fit.
