Silver Bullet rear doughnuts
Started by TheBoy, 22 September 2012, 13:28:30
Gap is too narrow on drivers. Might be the bush failed, collapsed, allowing sub frame arm to drop nearer the triangular plate. Hence gap is narrower.
As the drivers side also sits low, check spring first. If ok the plate needs to come off for a butchers. Jack on the subframe arm and it shouldn't move from the chassis.
Quote from: chrisgixer on 22 September 2012, 13:41:43
Think tthats the way its jacked? Only drivers side jacked
Lazy arse. ;D jack both sides. ;)
...but I don't think it is, iirc that's how it was parked up, going by feel.
If I remove plate, how much trouble am I in if it moves? Thinking about the hassle we had before...
If it moves you'll need a hand, but if you place the jack on the four holes in the subframe arm it won't.
Jack both sides to check the gap, (or let the jacked side down) so the car sits evenly.
But if removing the plate only jack one side. Saddle on the four holes of subframe arm.
Then loosen The centre (18?) bolt. If it spins freely, remove all the bolts and the plate. If the bolt us nipped, don't remove the plate.
Unjacked, and rear bounced to settle.
Drivers:
Passenger:
Both sides, I can get index and middle finger in between plate and arm, with a bit of wiggle room.
First time I've seen the pics, drivers does look lower?
Needs some waxoil on those metal bits  ;)
Thats not a tear, BTW, its just clean. Presumably where it compresses when under load?
With a lever in them, how much do they move? That compression rub could be a sign that the top is already split :-\ it is an assumption that these only fail from underneath.
