Author Topic: OOF Cambelt DVD on laptop  (Read 4280 times)
Re: OOF Cambelt DVD on laptop
« Reply #15 on: 24 September 2012, 18:29:36 »
Been using VLC for years on a number of pcs - from win2000 through to Win7 - never had a problem with it locking up, always worked ok even on odd formats (such as cctv clips) and never tried to install any toolbars :y
Has for a while now, but does prompt first
Martian
« Reply #16 on: 30 September 2012, 12:12:46 »
Just years of trying to play videos, windows media player always moans about codecs. VLC just works, its not cluttered with rubbish I don't want. It just plays videos, its works well & reliable. I've not used WMP in years
As someone who used Media Player every day, its the most solid, reliable one out they for Windows, by a considerable factor.
VLC ignores most standards, and is prone to locking up. It has no place on my PCs.
I'm with TB on this one, WMP plays absolutely ANYTHING I present it with without any issues at all once it is aware of what codecs are available to use.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 30 September 2012, 13:03:17 »
wmp is rubbish imo  vlc player all the way. :y bet it would even play a vhs video if you could get it in the draw. ;D ;D ;D ;D
« Reply #18 on: 30 September 2012, 14:56:50 »
*Sigh*
Why is WMP rubbish? Its simply a shell for the media interface built deep into Windows. Being a core Windows framework, the media interface is a de-facto Windows standard, and is rock solid (but like IE, at the mercy of 3rd party codecs).  As WMP is just a shell for this framework, it has all the same advantages.
VLC on the other hand, is a kludged app trying to do it outside of the Windows provided framework. And it shows.
Steve B
  • Leicestershire
« Reply #19 on: 30 September 2012, 16:23:19 »
*Sigh*
and thats why..... :y for quality yes wmp wins all the way...try and put a mkv file to wmp...not very universal that way
« Last Edit: 30 September 2012, 16:40:23 by bigtimecube »
« Reply #20 on: 30 September 2012, 16:42:39 »
Agree wmp is not "rubbish" or "shite", but have always found that those video formats that wmp can't handle, work ok on vlc :y
Martian
« Reply #21 on: 30 September 2012, 17:32:29 »
WMP plays MKV's just fine, what's the issue?
Martian
« Reply #22 on: 30 September 2012, 17:34:08 »
WMP will play anything if the right codec is installed & registered correctly.
« Reply #23 on: 30 September 2012, 17:49:12 »
never had to download any codec for vlc.. it played anything without hesitation.. windows medial player is limiited with codecs..
Steve B
  • Leicestershire
« Reply #24 on: 30 September 2012, 18:36:38 »
when i chuck a mkv at it you get...
Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
Martian
« Reply #25 on: 30 September 2012, 19:11:08 »
That message means the correct codec is either not installed, or not registered correctly within Windows.
« Reply #26 on: 30 September 2012, 20:15:49 »
As Martian rightly points out, the media framework in Windows is exensible via codecs. Put on the correct codecs, *ANY* system making use of the media framework, WMP included, can play the file.
.mkv files, like all files, play fine in WMP.
VLC goes down a different route, and redesigns the wheel over and over, and this makes it buggy. Media framework is tried and tested.
Steve B
  • Leicestershire
« Reply #27 on: 30 September 2012, 21:37:43 »
Anyway i agree with martian and tb  ;D ;D ;D ;D ;D ;D you cannot beat media player :-\ :-\ :-\ just downloaded a codac pack :y so stop knocking it you lot ;D ;D ;D ;D ;D
