Author Topic: Help needed wire lose in fuse box..  (Read 2540 times)
OmegaAnglesey
« on: 26 September 2012, 19:41:30 »
Hi all, I just opened the fuse box compartment to to give it a dust but this wire fell out does anyone know what its for and where it goes ? :-\
Martian
Re: Help needed wire lose in fuse box..
« Reply #1 on: 26 September 2012, 19:49:04 »
That is home DIY wiring, so it's not going to affect anything that is standard to the car.
OmegaAnglesey
« Reply #2 on: 26 September 2012, 19:51:57 »
Could be why the alarm has stopped working (the alarm is an after market job) Although the indicators flash there's no sound from the alarm?
« Reply #3 on: 26 September 2012, 20:34:34 »
If you undo the two screws and pop the panel out, it might give you a bit more of a clue :-\
Both my taxi meter and roof sign are fitted in a similar fashion  :y
« Reply #4 on: 26 September 2012, 20:35:48 »
The fact that there is no fuse fitted could be because whatever it was wired in to run has already been removed ??
OmegaAnglesey
« Reply #5 on: 26 September 2012, 20:47:57 »
I have opened this fuse box many times to check, clean etc but this is the 1st time ive noticed this wire  :-\
OmegaAnglesey
« Reply #6 on: 26 September 2012, 23:35:35 »
So there's nothing to worry about then  ???
« Reply #7 on: 26 September 2012, 23:47:10 »
I'd have to follow it to see where it goes/went!  ;D ;D Do as suggested & remove the 2 screws holding the fuse box in place, it'll give you more room to see.  :y :y
