Author Topic: NCDC 2013 radio not working  (Read 4710 times)
martin341
  • Finland
  • I do my own stunts.
    • '00 3,0 MV6, '00 2,5 V6
« on: 27 September 2012, 17:45:03 »
Hei!
Car: Omega MV6 Estate, 2000.
Radio(FM) not working. Also ABS and TC lights are on most of the time( but not always) and therefore speedometer is not working. When the lights go out all gauges works and i can hear the differeny in the music sound( it goes louder and when i accelerate it goes even louder but if i brake, the sound goes down :() The radio(FM) stays dead.
One more thing. There is a word GPS written on the top right corner of the display. Does it have to be written in white if it works? Mine is red, so doesn't work?
All help appreciated,
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: NCDC 2013 radio not working
« Reply #1 on: 27 September 2012, 21:10:22 »
The radio/stereo faults are seperate to the speedo not working.
Speedo and ABS/TC faults are down to the ABS pump, it has an Electronic Control Unit attached to the side of it and these do develop faults, you could try cleaning it's wiring connector to see if that helps but usually best to fit a re-furbished item...
As for the stereo, the word GPS should be written in green, it sounds like you have a problem with the aerial connection, either on the roof or at the back of the stereo unit. Also another aerial connector in the passenger compartment, down by the footwell.
Brikhead
  • West-Mids.
« Reply #2 on: 27 September 2012, 21:11:03 »
Hello and welcome to the Forum, by the way. :y
« Reply #3 on: 27 September 2012, 21:45:49 »
What parts of the radio do not work? Just the radio? CD?
« Reply #4 on: 27 September 2012, 21:46:05 »
Oh, and is the car a saloon or estate?
Brikhead
  • West-Mids.
« Reply #5 on: 27 September 2012, 22:11:16 »
The car is an estate, so no fm reception via the rear window.
« Reply #6 on: 27 September 2012, 22:12:23 »
So no GPS and no Radio could point to a knackered roof aerial ;)
    • 530D M Sport, 330i Coupe
« Reply #7 on: 27 September 2012, 22:14:04 »
Sounds like the lack of speed pulses are affecting the SDV function of the headunit
Brikhead
  • West-Mids.
« Reply #8 on: 27 September 2012, 22:31:45 »
So we're agreed then!?  ;D
martin341
  • Finland
« Reply #9 on: 28 September 2012, 04:10:40 »
Thanks alot, will digg into it in the weekend.
mindaz
  • IRL , UK
« Reply #10 on: 29 September 2012, 09:10:26 »
the same (similar) problem I had  :(
please read  ;)
http://www.omegaowners.com/forum/index.php?topic=105263.0
Vauxhall/0pel 0mega 2.5 , 2002 , CD
martin341
  • Finland
« Reply #11 on: 03 October 2012, 15:11:15 »
I have a new question. Is there any chance that the cd player and fm thingi from a CDR 2005 unit fits into NCDC unit? Maybe someone have any expierience.
Cheers,
Martin
« Reply #12 on: 03 October 2012, 16:35:00 »
Cheers,
Martin
Nope
mindaz
  • IRL , UK
« Reply #13 on: 03 October 2012, 17:05:59 »
you got PM , Martin  :)
