Promotion on at Eurocarparts
Started by Grrrrrr, 28 September 2012, 20:28:11
Manual Elite V6
Quote from: Guffer on 29 September 2012, 13:33:02
Hmmm maybe I should pre-buy some oil ready for when I get back.....
...how much oil does an XJR (1997) take chaps?  ::)
:o ::) I think you would want to avoid a 1997 XJR at 8litres of oil, the V8 from 1998 take only 6.5litres  ;)
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
Grrrrrr
Not as bad as the Range Rover @ 9.5 litres of oil per change!
Work is the curse of the drinking classes (Oscar Wilde)
Gaffers
Quote from: Manual Elite V6 on 30 September 2012, 12:36:24
Ok, tell me the V8 is better than the straight 6 and I'll shut up ;D ;D
It's a jaaaaaaaaaaaaaaag man and it's got the proper jaaaaaaaaaaag engine in it :y
Quote from: Guffer on 01 October 2012, 03:15:01
Yes, an oafish, uncouth V8 in favour of his beloved straight 6 will have Sir William Lyons rotating in his grave, for sure. Mind you, I suspect the current brand of Front wheel drive, estate, rebranded repmobiles carrying his badge will already have rendered him pretty dizzy. ;D
..although, having said that, the first time I had a drive in a V8 engined XJ, I had to ask if it was the V12. :-*
Quote from: Grrrrrr on 30 September 2012, 15:49:47
Which needs changing VERY regularly on the V8!
Not needed at that age, by the time it needs changing it will have been written off due to chassis rust.
Quote from: Marks DTM Calib on 01 October 2012, 11:07:52
Yep. Just ask aaronjb where the crispy bits will be. ;D Was quite shocked at the state of his donor. Not far off being held together by the wiring loom. ;D
Gaffers
Quote from: Kevin Wood on 01 October 2012, 11:46:16
Subliminally I must have the same fears as the first job (prior to the service) is rustproofing what's left of the underside  ;D ;D ;D
If it's any consolation, when the worst does happen, it's clearly great fun cutting them up with a plasma cutter.
