Author Topic: Reversing Sensor  (Read 5544 times)
waspy
Reversing Sensor
« on: 01 October 2012, 11:24:49 »
I have reversing sensors on the Estate. In warm weather they work fine, but when it cooler or cold the audible sound sounds continuously just like you're parked right up to something.
The guy who I bought her off says it's always done this, but I would like it to work as it should.
I've checked the bumper sensors & they seam ok :-\
Any ideas?
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: Reversing Sensor
« Reply #1 on: 01 October 2012, 15:53:23 »
Mine has been disconnected for 3 years now with similar problem - it is a wiring loom problem allegedly.
« Reply #2 on: 01 October 2012, 17:50:27 »
Factory fit, or nasty aftermarkets?
waspy
« Reply #3 on: 01 October 2012, 18:00:11 »
Factory fit :y
waspy
« Reply #4 on: 01 October 2012, 18:01:40 »
I should add the previous owner had the car for nearly ten years & it's always done it, if that helps any :-\ :-\
« Reply #5 on: 01 October 2012, 18:09:52 »
Entwood posted the diagnostics routine for them...
twiglet
  • Norwich, Norfolk
« Reply #6 on: 03 October 2012, 10:08:42 »
Might be worth whipping off the tow ball Pete, as it's been known for these to cause problems with the sensors.  :y
« Reply #7 on: 03 October 2012, 11:29:41 »
When it plays up, the faulty sensor(or sensors) doesn't tick. All working sensors, when touched very lightly with the right pressure can be heard/felt to tick. Much like an electric fence, but you won't be electrocuted obviously. ;D
That in addition to Entwoods guide, which involves removing the fuse shaped resistor from the loom to activate diagnostic mode which bleeps 1-4 to give the faulty sensor, should help diagnose which loom or sensor.
Then it's a case of removing the bumper and finding the fault.
IME if the bumper has been removed, and hence the sensors have been unplugged( as opposed to removed from the bumper) they sometimes give a bad connection on re connection. The little rubbers in the plug connector get filled with dust and crap, and electrical cleaner makes the rubbers swell up and then the plug won't go in.
Or it's a fault, broken wire, in the loom etc. no experience of a failed sensor, it's always been a connection problem IME.
« Reply #8 on: 03 October 2012, 13:15:40 »
I'd agree with Chris .. to a point .. :)
When mine played up all the diagnostics were inconclusive ... one minute one sensor, next another ... the eventual fault was found to be ....
A damaged loom from when the rear bumper was resprayed ... the idiots had obviously "stretched" the cables and water had got in ... I'm guessing the weird electrics that produced damaged some sensors
Replacement loom and 3 sensors later .. and all working fine ... :)
waspy
« Reply #9 on: 03 October 2012, 13:42:33 »
Tow bar removed James :y It weighs too much to carry around all the time ;D
waspy
« Reply #10 on: 03 October 2012, 13:44:29 »
Thank you both for the info. I'll do some investigation work :y
twiglet
  • Norwich, Norfolk
« Reply #11 on: 03 October 2012, 14:18:08 »
In that case, can I have it?  ;D
« Reply #12 on: 03 October 2012, 19:37:36 »
Spoken like a true pikey ;D
waspy
« Reply #13 on: 03 October 2012, 19:47:57 »
PMSL  ;D ;D :y
« Reply #14 on: 03 October 2012, 19:58:39 »
Nah .. a true pikey wouldn't have asked .. he'd have just taken it ...  :)
