Author Topic: Maps on CID  (Read 2810 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Maps on CID
« on: 01 October 2012, 18:21:45 »
Does the colour display use a different disc to GID when using the Sat Nav? When I select map view it just comes up blank. Everything else seems to work ok.
    • 530D M Sport, 330i Coupe
Re: Maps on CID
« Reply #1 on: 01 October 2012, 18:25:17 »
Black screen?
doz
  • Southampton
Re: Maps on CID
« Reply #2 on: 01 October 2012, 18:34:04 »
Yep. With a little box top left which I guess is for switching between pictograms or maps. Screen is working fine in all other ways
Re: Maps on CID
« Reply #3 on: 01 October 2012, 18:34:52 »
12 Pin RGB cable isn't plugged in  :y
doz
  • Southampton
Re: Maps on CID
« Reply #4 on: 01 October 2012, 18:46:02 »
Poo. Yep I only put the one plug in the back of the screen. Didn't see second plug. Will I need to find one a lead now or is it hidden down the dash some where? I had the Sat Nav in the car originally but with a GID. I just swapped the head and screen but the head unit was a like for like swap.
Re: Maps on CID
« Reply #5 on: 01 October 2012, 18:48:08 »
Yep, normally taped to the loom coming from the main plug at rear of display
Re: Maps on CID
« Reply #6 on: 01 October 2012, 19:56:46 »
Very early facelifts lack the RGB loom if it didn't come with a GID. Later ones, its tucked behind the webbing behind where the screen goes, normally some foam around plug, and masking tape around that.
doz
  • Southampton
Re: Maps on CID
« Reply #7 on: 01 October 2012, 22:30:55 »
Mines an X plate which came fitted new with a 2013 and GID. I'm guessing I'm in luck with that cable
doz
  • Southampton
Re: Maps on CID
« Reply #8 on: 01 October 2012, 22:52:46 »
Oh one more question. I take it I don't have to remove the stereo cage and plug this cable in that end as well?
Re: Maps on CID
« Reply #9 on: 01 October 2012, 23:14:49 »
Nope
doz
  • Southampton
Re: Maps on CID
« Reply #10 on: 02 October 2012, 17:30:17 »
Cheers guys. I now have pretty pictures to look at while I drive.  :y
Page created in 0.039 seconds with 20 queries.
