Author Topic: Non starter  (Read 5598 times)
Re: Non starter
« Reply #15 on: 22 April 2008, 20:56:44 »
Consider getting the one you have repaired.....try these fine people:
http://ecu-testing.com/contact_us.html
I gather they're more for ECU's. My gut instinct is that it'll be the pump :(
Re: Non starter
« Reply #16 on: 22 April 2008, 20:57:48 »
My money is on the EDU bolted to the top of the pump......was there not one on the old pump you took off that you can try?
Re: Non starter
« Reply #17 on: 22 April 2008, 21:22:24 »
EDU standing for what exactly? Someone had already been having a play with the top of the pump before I got to it. I'd considered having a play at frigging something ... (I wasn't too sure what  :-? ;)) but when I removed the top I discovered the ribbon cable in there was also ripped. At that stage I decided to look for another pump. Isn't hindsite wonderful?
Any suggestions about frigging it though Mark would be most gratefull.  ::)
Re: Non starter
« Reply #18 on: 23 April 2008, 15:02:55 »
No way to frigg it.
The EDU is the pump controller, this engine is a piston pump with full ECU control and the EDU is the pump interface module.
The company listed do repair the EDU's
« Last Edit: 23 April 2008, 15:12:07 by Mark »
Re: Non starter
« Reply #21 on: 23 April 2008, 23:24:04 »
Bargain!
http://cgi.ebay.co.uk/Vauxhall-Astra-1-7-DTI-TD-Diesel-Pump-ECU-EDU-16267710_W0QQitemZ110244655931QQihZ001QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or:
http://cgi.ebay.co.uk/Vauxhall-Astra-1-7-DTI-TD-Diesel-Pump-ECU-EDU-16267710_W0QQitemZ160226125245QQihZ006QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Wrong engine I think. Mine's a 17DTL single cam GM engine, I'm sure that the DTI is the twin cam engine - both listings refer to the Izusu enggine. You reckon it's the ECU or the actula fuel injection pump? Going off what I could find re the fault code I'd pretty much assumed it was the pump, but I'll love to be shown I was wrong. ;) My ECU is quite a long afair that lives under the passenger front wing.
