Tyre construction ( bit boring! and pic heavy )
Started by feeutfo, 04 October 2012, 00:46:52
Tried to do a spot of window shopping on the blackboots site earlier, but computer said no :-\ wouldn't even attempt to load the shop page :-\
Quote from: ex taxi al on 28 December 2012, 19:48:53
I still get in fine .. to the main site
http://www.wheels-inmotion.co.uk
but the link to tyres fails ...  :(
2woody
Quote from: chrisgixer on 28 December 2012, 05:12:12
Quote from: chrisgixer on 28 December 2012, 04:49:25
What am I missing? :-\
...and don't say custard. ;D
sorry again, Chris....
How it works is this.....
The car manufacturer designs a car and chooses a hub height and a wheel revs per mile. It then goes shopping to tyre manufacturers and tries either prototypes or simulators on the manufacturer's first guess at the tyre. Of course the weight is important too, but the plain fact, at least for passenger cars is that the tyre manufacturer would never develop a tyre with a load index less than likely for any vehicle.
It certainly isn't the case that the manufacturer requires a tyre to match the load index that it has designed.
of course, the manufacturer and tyre supplier keep working together and the detail geometry, construction - and by that, I mean things like tread block radii, etc., and compounds, so that any potential problems have been ireoned out prior to launch.
RobseyMV6
Why you running 235 40 18 Chris?
245 40 18 here, find 245 to big?
Quote from: RobseyMV6 on 31 December 2012, 00:21:31
yes very slightly too wide, slight rubbing on the outside edge on the wheel arch liner under full compression with irmscher springs giving 30mm drop. Only slight.
10mm less width and all is well.
Irmscher recommend -1.40 camber with their suspension which might give clearance.
But -1.40 is too aggressive on tyre wear, and too twitchy in a straight line. Mine is set to -1.10 as normal.
So went for 235.
You prefer 245 width?
Quote from: 2woody on 30 December 2012, 21:18:48
ok so Mr tyre maker turns up, and his tyres tramline like a bitch, what does he do to fix it, exactly?
And let's say you've got 18's fitted, what tyres would you buy? Exactly? :)
RobseyMV6
Quote from: chrisgixer on 31 December 2012, 01:22:02
So went for 235.
This time i'm not on lowering spring and can't remember if on my mv6 at the time with 245 but fair call, got 235's for from on plod as i think fronts rub on turn...  :(
2woody
Mr tyre manufacturer will go away and try altering compound and tread pattern until it works. Usually. I have known them give up, tho.
On 18's - I usually buy a set before each track-day and then finish them off on the road. Cheapest, always. On the couple that I've had that tramlined, I've always found it to be the car and not the tyres.
Quote from: 2woody on 01 January 2013, 23:48:59
since these ao1 where fitted, I think the rear wb bushes have failed, and the steering idler was replaced.
I could pick out the differences with the steering idler before and after. Slight steering play and a creak.
But I can't feel any difference with the rear wb bushes. ...another creak has developed so i need to check them again. But they where fine when ao1 where fitted because I checked while the car was jacked at the tyre fitters.
So, as I've made that about as clear as mud;
No tram lining.
Mo came off with worn in/outside edges and plenty of tread in the middle.
Rear bushes checked, and fine, while jacked at tyre fitters.
Ao1 went on, drove it away from the tyre fitters, instant tram lining.
Creak and slight play in idler, replaced, slightly better steering, tramlining no change.
Different creak developed, might be rear wb bushes, tramlining is same.
Conclude, mo don't tram line, ao1 do. Why?
Not tread pattern, it's exactly the same.
Don't think it's compound, grip and wear is very similar Afaict.
It's the narrower ao1 (235wide) the plays up so its not to do with width.
Mo where on both sets of sport stars in et30 and 38. No tramlining, it's not the et.
It's not the car as the before and after tyre change was night and day.
Ao1 pressures tried between 28 psi to 35. No affect on tramlining, just harsher ride.
IMO, it's the construction of the tyre, unless anyone else can think of another aspect that we could eliminate. ...?
Also, TheBoy has a sweet handling mv6 with worn Dunlop sport max TT.
He also has an elite with other issues, but new sc5. To me, the sc5 are poor in respect to tram lining.
The wheels have been swapped between the two cars. I wonder how the mv6 drives now...?
How many sets of ao1 have you had? It's not impossible to get a bad tyre..
What about the runout indicators - can you remember where they were and if you had a matched pair of tyres put on the front?
Just wondering if you could be chasing ghosts, so to speak..
Just two ao1 on the front.
Can't remember the lines being present, but I'll cirtainly look. :y
I know the mo red and green lines hung in there really well. Still present once removed.
I think you're still looking at it too simplistically. I suspect there is more than just "number of plys" or "sidewall material" etc etc between manufacturer specific versions of a specific tyre. In fact, you already know that in visual differences between the MO and AO1 variants.
Its more than likely that the compound will vary. The tread pattern will likely remain the same for a specific "model" of tyre, such as SC3.
