Tyre construction ( bit boring! and pic heavy )
Started by feeutfo, 04 October 2012, 00:46:52
I can check sport maxx tt and sc5 (generic) tomorrow. Too dark now
Quote from: TheBoy on 04 October 2012, 20:37:58
Get the torch out ::) ;D
Quote from: Lazydocker on 04 October 2012, 20:39:00
Time for chips, and its phishing down
Radar
Hankook Ventus V12 Evo: 235/45 ZR17 97Y Max. Load 730 kgs
Plies Tread: 2 Steel + 2 Rayon + 2 Nylon
Sidewall: 2 Rayon
Toyo Proxes T1R (PXT1R-1) 235 45 17 97Y
Plies - 2 Steel, 1 Rayon, 1 Nylon
Sidewal - 1 Rayon
Continental SportContact 3
Front
235 45 R17 97W (Extra Load)
Tread Plies 5: 1 Rayon, 2 Steel, 2 Polymide
Sidewall Ply 1: 1 Rayon
Rear
235 45 ZR17 94Y
Tread Plies 5: 1 Polyester, 2 Steel, 2 Nylon
Sidewall Ply 1: 1Polyester
goodyear eagle f1 asymmetric 2
plies sidewall 1 polyester tread 1 polyester + 2 steel 1 polyamide
Micheline pilot exalto
tread plies 1 polyester 2 steel 1 polyamide  sidewall ply 1 polyester
Potenza Adrenaline
plies tread 1 polyester 2 steel 1 nylon sidewall 1 polyester
Hmmm, now where did we get to with this.
Think I've just confused meself tbh. ;D
TB have you got your torch out yet? :)
Spoke to Dunlop technical today. They recomend the RT range, now that the tt has been superceided. RT being an out and out performance tyre, wet braking giving an A rating, and non of this lightweight fuel saving rubbish involved.
Althought they did say they don't officially do a tyre for the omega.  ???
Quote from: chrisgixer on 20 December 2012, 14:34:20
Yeah, but long since slept since then. Something to do with Raylon and Polyester.
YZ250
Same as Cem on the Goodyear F1's with the standard 235/45/17 and it tramlines worse as tyres wear down.
The following is nothing to do with Omega and is just for reference but our M Sport has :
Front 225/35/19 with Plies tread 2 Steel + 2 Rayon + 1 Nylon, sidewall 2 Rayon.
Rear 255/30/19 Plies tread 1 Rayon + 2 Steel + 2 Nylon, sidewall 2 Rayon
and this has zero tramlining on the same stretch of road but has suspension as hard as a bullet.
This all means a big fat zilch to me.   :-\
Incidentally, I found my Toyo T1R's 'V' pattern fairly good for lack of tramlining until they got quite low on tread.  :y
Quote from: TheBoy on 20 December 2012, 17:41:29
yep, not sure we'll get anywhere with this though. :-\
Quote from: chrisgixer on 20 December 2012, 18:40:39
We know the answer. Dunlop Sport Maxx TT. Except they are being withdrawn :(
Chris, I can say that increasing tire pressure will increase grip , decrease braking distance.. increase cornering ability (lateral-g)..
and decrease tramlining upto an extent (actual amounts may differ tyre to tyre)..
however, tramlining is a function of tyre/road friction-grip .. so a good quality high grip wide tyre will tramline .. you must be suspicious of grip if it doesnt tramline.. as YZ250 says tyres tend to tramline more when they wear and loose the "channels".. why ? because they losse the straight channels that give direction and  to an extent surface area increase .. :y
ps: of course ignoring comfort..
pps: I guess actual graph for grip vs pressure would be a U shape upside down so has a limit of course..
Quote from: cem on 20 December 2012, 19:13:05
Only that theory falls apart with the Dunlops I have on the Silver Bullet.  No tramlining (well, just starting to, but all 4 tyres are now spent), and the grip levels are superb.
The SC5s I have on TBE tramline all over the shop, and the grip is best described as "OK-ish", although other factors are at play on that bloody car.
