Author Topic: 3.2 code 1700  (Read 4206 times)
Re: 3.2 code 1700
« Reply #15 on: 07 October 2012, 19:15:47 »
P0730 is a GS820 code, incorrect ratio.  TIS doesn't list a Incorrect Ratio code for GS821, so suspect its a cock-up with TIS.
Shackeng - have you ever felt excessive slip, or occasionally the engine flares a bit on gear changes?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: 3.2 code 1700
« Reply #16 on: 07 October 2012, 19:50:15 »
No, just the incident described in my OP. Otherwise it has been perfect ever since I bought it last year. However I have only done about 3000 miles in it.
Krzys
  • Nottingham
    • Omega 3.2 MV6
Re: 3.2 code 1700
« Reply #17 on: 21 January 2013, 13:55:08 »
On the way to the airport last weekend, at about 30mph accelerating gently (as always ::)) there was a sudden jolt from the transmission, the spanner light came on, and I think it went into limp mode, as it was necessary to select first manually to get it to go decently. On arrival at airport hotel, a few miles later, I cleared the light after two restarts, and had no problems on the 90 mile return trip (although that was nearly all at 80 on motorways). The stored code is 1700 (service vehicle soon request from transmission control module) so I guess that the auto box could do with a service as it is now at 52k and 11 years old. Any comments? :y
I'm having similar symptoms with my box, have had the oil changed in the autobox, though it is much smoother I'm still getting the "thud" when it decides not to change up to third or fourth! Plus after a bit of town driving the cab smells like burning oil!
EML light is on with codes 0420 & 0430 (Cats) and 0700 code for the box!
Re: 3.2 code 1700
« Reply #18 on: 21 January 2013, 17:59:28 »
PM Marks DTM Calib (West Bridgford), and see if he can read gearbox - he has the full Tech2 setup :)
Krzys
  • Nottingham
    • Omega 3.2 MV6
Re: 3.2 code 1700
« Reply #19 on: 21 January 2013, 19:34:12 »
Ah, thanks, I'll drop him a message! Much appreciated! :)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: 3.2 code 1700
« Reply #20 on: 21 January 2013, 22:25:26 »
Did you change the crank sensor?
car5car
  • Florida USA
    • 01 Cadillac Catera
Re: 3.2 code 1700
« Reply #21 on: 22 January 2013, 02:05:08 »
I saved this info, when I was diagnosing dead ABS module:
The P1700 is just a request for the check engine light, and this is caused by the U2108. The U2108 is basically telling you that the Electronic Brake and Traction Control Module (EBTCM) is not communicating with the powertrain control module, or the transmission control module.
The very first thing we must do is verify that the fuses that power the ebtcm are not blown and that they are powered. At this point I would like you to verify that the fuse labeled ABS in the fuse block is not blown and that it is powered with the key in the on position.
I would also like you to verify that the fuse labeled V1 inthe power distribution box is not burnt and that this is powered also. After this we need to move to the ebtcm to verify that you have voltage at pins 15,17,18 and that you have a ground at 19 and 16.
This would verify that the ebtcm is getting the proper voltage supplies to operate. The end result of this may possibly be a faulty ebtcm, but at this point we really need to check these items prior.Feel free to contact me with any questions at this point! Thanks!
P1700....Malfunction Indicator Lamp requested by trans control module
This code (U2108) is a communications error with the ABS module. This goes hand-in-hand with the TC and ABS lights and code P0500. The VSS is wired to the ABS first, then carries over to the ECU and speedometer. I found this out the hard way with a buddy's Catera. When the ABS module has communications errors, the speedometer loses signal from the Vehicle Speed Sensor (VSS).
Most of the abs ecu tcu proplems cuesd by low A OR NON SUTABLE BATTERRY
if u have the abs and the tc lights no speedo u may check the wheel sensors first of all ,U2108 in most cases reqest to replace anew (EBTCM) IF U GOING DRIVE WITH U2108 ERROR U WELL HAVE ANEW ERROR CODE P1700 AND WELL FORCE PROPLEMS WITH THE TCU , AFTER REPLACING ANEW EBTCM YOU MUST REMOVE ALL THE ERRORS CODES FROME THE MEMORY
01 CADILLAC CATERA 3.0 engine (Omega)
Krzys
  • Nottingham
    • Omega 3.2 MV6
Re: 3.2 code 1700
« Reply #22 on: 22 January 2013, 09:38:36 »
I haven't changed it yet as it didn't throw up any errors for it but I have read it can lead to problems with the outbox! I had the gearbox ECU read last night with a Tech2 which had a "Not present" error with engine speed input to transmission, its been cleared for now to see how it behaves but the gearbox got stuck in second again half a mile down the road and "thudded" into third, no lights were thrown up though, usually when you get a violent jolt it'll go into limp mode on the box! I still think the failing cats are contributing to this!
Re: 3.2 code 1700
« Reply #23 on: 22 January 2013, 18:43:12 »
That is incomplete, hence the requirement to read the codes from the TCM and ABS :y
