Author Topic: Front lower suspension arm bushes  (Read 8125 times)
Re: Front lower suspension arm bushes
« Reply #15 on: 13 October 2012, 11:10:18 »
If the rearward bushes are OK, I'd be inclined to poly the fronts, and if necessary, replace balljoints.
Personally, if the arms look OK, and the rears are knackered as well, I'd be inclined to rebush rears, poly fronts, and replace baljoints if necessary.
If we just need to replace the fronts and decided to poly them would we need the geometry set up afterwards?
in an ideal world it should be done at least once a year anyway ;)
I would advise getting it done once everything is right again. I know it's not cheap and a bit of a pain for those of us who are miles from a decent, WIM approved centre but it's cheaper than a set of tyres ;)
« Reply #16 on: 13 October 2012, 11:11:14 »
« Reply #17 on: 13 October 2012, 11:11:40 »
No, only need full geo when removing/replacing complete wishbone :)
True, but see my above post ;) Depends how soft the bushes were when it was last set up really ;)
« Reply #18 on: 13 October 2012, 11:14:28 »
Question OP asked re; geo was answered correctly ;) but as you say Paul, wouldn`t hurt to get it done :y
« Reply #19 on: 13 October 2012, 11:16:58 »
Good point geoffr70
 This topic has been covered many times before surely members have got the just of this by now
Not necessarily, and no doubt the same question will be asked again in the future. As the OP said, she tried searching to no avail so asked for advice. That`s what the forum is all about
« Reply #20 on: 13 October 2012, 12:11:31 »
Not arguing with you over that Rob ;) The answer was indeed correct... I just went into a little more detail ;)
TBH, if I lived closer to WIM (as I haven't found anywhere else I trust yet ::)) I'd get mine done every 9 months or so anyway as I do 20-25k per year anyway ::)
That said, I haven't had this one set up at all and I've owned it 18 months :-[ Just seem to have other things in the pipeline that are taking longer than planned ::)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #21 on: 13 October 2012, 23:24:38 »
not highjacking this post but today noticed that shed 4 needs new wishbones and links which i have was wondering has anybody heard weather pedders have sourced poly bushes for the omega yet,as would like to poly the bones i have and the pedders might be cheaper than powerflex (every little helps)..
Hoof'land storeman.
« Reply #22 on: 13 October 2012, 23:32:44 »
think powerflex is the only option. And only for the front horizontal bush.
biggriffin
« Reply #23 on: 13 October 2012, 23:56:06 »
 just hopeing there might have been another option.
Hoof'land storeman.
Page created in 0.024 seconds with 16 queries.
