Author Topic: Omega CCRT700 Changer problem  (Read 4645 times)
TamDodd85
  • Fife
  • Mostly Flat out
    • Omega 3.0V6
« on: 14 October 2012, 19:49:15 »
Hi folks how ya all doing???
I have a CCRT700 with Blaupunk changer in the boot
When i got the car there was an aftermarket CD player i ripped that out as i wanted the changer and stering controls to work. put the tape player in and put the code in on the dash that was fine.
But the changer has been locked out it says CD SAFE with no numbers near i.e how many trys i can enter.
I went to a car audio shop and the guy wanted £35 for unlocking it. no way paying that!
Any ideas if i can do this myself or a much cheaper way to do it???
Cheers
Tam
98 Omega 3.0 V6 Black
Re: Omega CCRT700 Changer problem
« Reply #1 on: 14 October 2012, 21:02:19 »
Do you have the code for the CD changer? If not you'll have to pay out anyway ....... and what's £35 vs the price of a new changer?  ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 14 October 2012, 22:51:21 »
Radio & Decoding Technician
www.dndservices.co.uk
TamDodd85
  • Fife
  • Mostly Flat out
    • Omega 3.0V6
« Reply #3 on: 16 October 2012, 17:30:54 »
I have the code for changer but it wont let me enter it.. it just says CD SAFE i think (If i read the book right) that means its locked out. i cant enter any code for the changer and it needs unlocking with a computer???
Thanks for the advice more is welcome  :)
« Reply #4 on: 16 October 2012, 18:16:43 »
ignition ON
Head unit OFF
Press & hold CD while you turn the head unit ON
That should give you the opportunity to put the code in  :-\
TamDodd85
  • Fife
  • Mostly Flat out
    • Omega 3.0V6
« Reply #5 on: 17 October 2012, 19:19:44 »
Thats what the book said mate i tryed and tryed that but what im saying is its locked out as when you enter the code there is a number (10) or (8) thats the attemps you have left to enter the code.
Mine as been locked out as i think some1 has entered the code wrong 10 times so its locked out.
Tape/Radio was fine i followed the book and worked 1st time. so i knew what i was doing for the changer.
And i havent entered anycode for the changer as i could'nt as it was locked when i got it.
Its very nippy!!!!!!
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #6 on: 22 October 2012, 20:39:31 »
hi all
long time no posting  ;)
to the op (not sure if this will work) leave the cd player on, might be several hours it could reset itself, also i seem to remember that there was a certain way round to install the radio and cd changer   :-\
TamDodd85
  • Fife
  • Mostly Flat out
    • Omega 3.0V6
« Reply #7 on: 27 October 2012, 12:20:26 »
Hi no problem with the post time :)
I Will give it a try!
How do u mean a way around in installing??? as in put the changer code in before i put the radio code in???
Thanks for the help by the way :)
TamDodd85
  • Fife
  • Mostly Flat out
    • Omega 3.0V6
« Reply #8 on: 11 November 2012, 12:08:15 »
Thanks for the help folks
I called a few auto sparkys they said they wont touch it for sum reason?
So i just put an aftermarket cd player in as i cant stand the pish thats on the radio all the time!
Thanks again!
Tam
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 11 November 2012, 16:34:22 »
If all 10 attempts used up, then needs manually unlocking - by all means give me a ring, but make sure you are sitting down when you do as its a bastard of a job
