Author Topic: Wanted various FL electrickery bits.  (Read 7277 times)
Re: Wanted various FL electrickery bits.
« Reply #15 on: 17 October 2012, 19:44:14 »
PM sent :y
I'm after the following parts:
1x late Elite electric rearview mirror with two? flat plugs rather than the single square black plug. Might include rain sensor, but not sure :-\
1x GLOSS ashtray trim, must be near mint pls.
*1x late facelift estate wiper stalk with MID control plus car plug and six inches of loom*
Ta muchly,
Al :y
Edited to add item ::)
Edited again to change another item ::)
Edited to remove aquired items :y
« Reply #16 on: 19 October 2012, 13:12:29 »
Revised list as have sorted most of it. Thanks Albs :y
1x Washer bottle level sender with plug and six inches of loom
1x Coolant level sender plug and six inches of loom
1x Oil level sensor plug and six inches of loom.
1x late Elite drivers door switch with centre mirror control.
1x late FL estate wiper stalk with trip computer switches plus six inches of loom.
Ta muchly,
Al :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #17 on: 21 October 2012, 13:26:34 »
I have an auto dimming rear view mirror and may be able to find a stalk too, don't know about the loom though unless a saloon one is any good?
« Reply #18 on: 22 October 2012, 01:38:51 »
Cheers Rich :y
The wiper switch needs to be an estate one :-\ might buy new. The part loom is both sides of the 'extra' plug for the trip computer switches :y
It should have 3 wires, either white+red+brown or brown/white+brown/red+brown if that helps.
Is the mirror a later one with the flat plugs rather than the single black cube  :-\
Brikhead
  • West-Mids.
« Reply #19 on: 22 October 2012, 09:25:39 »
The wiper switch needs to be an estate one...
Yes Mate, I've broken a few estates, need to check in the shed parts storage department...
The mirror is still fitted in the car, just need to check under the headlining regarding connections, I'll let you know.
Cheers,
Rich.
« Reply #20 on: 22 October 2012, 11:18:40 »
Much obliged :y
Brikhead
  • West-Mids.
« Reply #21 on: 22 October 2012, 18:56:27 »
I've checked the mirror and it has the single black block connector. Any use to you?
I've not ventured into the shed yet...
« Reply #22 on: 22 October 2012, 21:46:22 »
Pm sent :y
« Reply #23 on: 25 October 2012, 22:40:22 »
Ta muchly,
Al :y
