Pages: 1 [2] 3  All   Go Down
Author Topic: Lumpy idle  (Read 7603 times)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #15 on: 20 October 2012, 20:46:10 »
Did you mean oil the egr?
Re: Lumpy idle
« Reply #16 on: 22 October 2012, 08:01:30 »
Sorry, I was referring to icv only. Clean with carb cleaner, light lube, re fit. :)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #17 on: 22 October 2012, 10:39:08 »
Thanks Chris - i did the icv as you stated and actually did the egr valve again and lightly oiled it - she is still stuttery on idle :-\
Re: Lumpy idle
« Reply #18 on: 22 October 2012, 17:19:06 »
Assuming TB checked it for air leaks, sounds like dicky icv. Ime, it might be worth repeatedly cleaning, lubing icv, as my old 2.5 icv responded well eventually. Or fit used?
See what others say. :)
Re: Lumpy idle
« Reply #19 on: 22 October 2012, 19:11:35 »
Might be worth blanking the EGR.
Didn't get time to measure the MAF, as OP was already getting his knackers chewed off for being late to a birthday party ;D
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #20 on: 22 October 2012, 21:18:48 »
Thanks guys - i will clean icv a few times over the next few days.
Then i will blank egr as per link below:
http://www.omegaowners.com/forum/index.php?topic=20307.msg306008#msg306008
This could be a good addition to the maintenance guides if admins. see fit?
P.S. I got back from Cuttleslowe in record time - i had a 911 and an aston martin pull into the 2nd lane to let me past!
« Last Edit: 22 October 2012, 21:29:33 by Radar »
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #21 on: 30 October 2012, 19:15:26 »
Update:
I have blanked off egr and cleaned icv several times (over the past week) The idle is ok for a bit, then the revs drop and she shudders and this process repeats itself.
Also noticed that when i move from park to d sometimes the 1 light flashes.
Any pointers appreciated :y
« Last Edit: 30 October 2012, 19:17:01 by Radar »
Abiton
Re: Lumpy idle
« Reply #22 on: 30 October 2012, 19:58:39 »
If you haven't already done so, might be worth going round with a can of carb cleaner searching for air leaks.
Re: Lumpy idle
« Reply #23 on: 30 October 2012, 21:50:40 »
Paper clip it for codes. :)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #24 on: 31 October 2012, 09:00:20 »
Cheers guys - will spray carb cleaner around and paper clip again - (for info. i did paper clip after the oxford meet and no codes were present)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #25 on: 03 November 2012, 19:18:37 »
Paperclipped and just came up with 12 and 31. No signs of leaks when spraying carb cleaner with engine running.
I cleaned the breathers as per guide including vent housing - the small pipe to the housing was clear but just put a pin in there to clean it and a squirt of carb cleaner, the larger one i could not get off so i squirted a small amount of carb cleaner into left side big pipe (i blew down it first and seemed clear) and the other large breather pipe.
On the breather box the "pipe" that leads to the two small holes on the box had quite a bit of carbon come out - this was cleaned to within an inch of its' life!
Then did an oil change and to get the oil warm let it run for a couple of minutes - it was popping / stuttering all over the place. Thought any gunk would come out with the old oil but even after the change it is still popping (though not as much as before).
I double checked everything was put back together correctly and i believe it has been. I couldn't see where the other small breather pipe connects to - it looks secure but could not follow its' path - where does it go?
I hope i haven't messed it up by squirting carb cleaner down the big 2 breather pipes but the engine is popping like its bonfire night :P
Any help / pointers much appreciated :y
Re: Lumpy idle
« Reply #26 on: 03 November 2012, 21:37:11 »
Popping is a misfire. No?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #27 on: 03 November 2012, 22:02:06 »
I woulod say no. It sounds like when you squirt carb cleaner and it pops - If you know what i mean?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #28 on: 03 November 2012, 22:59:45 »
More like a backfire
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #29 on: 04 November 2012, 15:00:16 »
Took the plenum off and it looked like one of the o-rings was not seated properly. Put the plenum back on and no more popping / backfiring :y
The idle is still stuttery though :(
Pages: 1 [2] 3  All   Go Up
