Author Topic: Drivers exh manifold gasket  (Read 3234 times)
Re: Drivers exh manifold gasket
« Reply #15 on: 23 October 2012, 18:51:39 »
Really not sure it will work again as there are about twenty pipes/connectors that need to go back in the same place
Keep at it , i been watching how this goes  ;D :y Sounds like a mare of a job though  ::)
amba
  • Medway towns
    • German V6
« Reply #16 on: 23 October 2012, 18:55:43 »
Sounds like you are getting there  :y
Coolant bridge SHOULD have a dowty washer .( metal washer with a rubber inner ) on both sides of the bridge..1 under the bridge /then the bridge/another above then hollow bot through the middle and screw into the block...do them up as much by hand as possible to ensure thread hasn,t crossed then when you are certain all is seated and thread isn,nt crossed get the socket on it and torque down to spec..think 30nm from memory but need to double check.
4 dowty washers required  :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #17 on: 23 October 2012, 19:12:20 »
Cheers again amba, hands are shredded to coil pack levels  :'( but it's going ok. Had to source a mix of dealer / pattern parts due to cost. £3.58 for an m10 downpipe nut FFS
amba
  • Medway towns
    • German V6
« Reply #18 on: 23 October 2012, 19:46:18 »
Thats about right  >:( for VX I suppose.
Don,t skimp on dowty washers/manifold gasket..multi layer/or copper helicoiled nuts as they really need to by VX. You might also struggle getting coolant transfer pipe "0" ring seal from anywhere else but studding is pretty standard imho.
Its easier putting it all back together as you will remember where the ackward bits are and work around it  :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #19 on: 27 October 2012, 09:05:18 »
Well nearly done with this, just got to put the coolant tank back in and refit the downpipe. Worst bit's were getting the heatshields back on and the injector rail was a nightmare due to the LPG gubbins, took a nick out of the little plastic ring bit at the end of an injector but it is all back in tight enough, hope this isn't going to cause issues :-\
Pleased with the vaux studs, gasket and nut's quality if not the prices!
amba
  • Medway towns
    • German V6
« Reply #20 on: 27 October 2012, 09:10:44 »
Pleased to hear your nearly done,and fingers crossed when you start her up the sound will be just ...." sweet " :y
