oh fudge cakes!!!
Started by Kai, 22 October 2012, 12:55:49
And its only metal, bones are less replacable.
Kai
this is true Jamie thank you, not high spec only CD will have a few bits before it leaves the country in a steel box haha
Guess I just couldn't stay away for the fourth time....
jonny2112
Thats a real pity pal, but glad you're okay  :y
Boot lid and bumper bolt on so no issue there really, but the rear wing, that will never be the same obviously, but coud be made road worthy. ...with a big hammer. Or cut out a good wing and Weald it in to replace the battered bit. But your talking cash then. :(
Insurer doesnt necessarily need to know, or buy back the write off as said. You'll get the wreck and a cheque to the value of the car, less the scrap value.
I believe Robsy replaced a rear wing on an Estate. Guessing the saloon is a bit less involved.
Sorry to see this though Kai. Best of luck with it, what ever you do.
...actually on second look, the boot floor will be buggerd too.  :'(
Changing the rear quarter panel is straight forward enough :y Rob went overboard because he cut the whole rear wing out, inner and outer ::) just undo the spot welds and pull the outer off, straighten the inner, boot floor/rear panel can be assessed with the bumper off. Replace bootlid then straighten inner wing and go from there... simples :y
Quote from: ex taxi al on 23 October 2012, 05:32:33
[/quote
agreed.. easy repair..
Raymienets
Quote from: Kai on 22 October 2012, 19:55:15
If its a CD you want to pull the front windscreen rubber trim of give me price. Cheers
Rog
" oh fudge cakes!!! "
How polite is that under the circumstances !   ;)
Anyway bad luck. Damage like that on an old car is lilkely to be terminal.  :'(
Kate
You must have been terrified when that happened.
tomh23
HockeyDave55
Go on, fix her up mate! :y
