battery going flat
Started by scottambrose, 23 October 2012, 10:41:02
ffcgary1
Start with the simple stuff first, pull all the interior bulbs first and and include the boot / tailgate lamp as well, then see if the battery still goes flat, also you need to check the output from the alternator because if it is fubar then you will always have the problem
Does your car have a factory fitted alarm system? if so check the power sounder is ok as this is also a problem area and could be causing your system to drain currant.
Jaguar XJ6
scottambrose
Power sounded disconnected and removed boot light removed and disconnexted al interior lights and will see if it dips down again
