Old Cars & New Reg
Started by tunnie, 26 October 2012, 09:03:14
I thought you could not put a newer plate on an older car? Ie put a 02 plate on a Ford Escort?
But today I saw a classic Merc 300, beautiful example looked like new! But it was on an 03 plate  ???  :-\
If it's never been registered, and is essentially unused, then it gets a current registration, which is nice :y
There are a handful of R, S and T reg W124s running around :y
It was one of these... & defo on an 03 plate:
Quote from: tunnie on 26 October 2012, 09:03:14..... But it was on an 03 plate  ???  :-\
You sure it wasn't a mis-spaced old number ie Oscar rather than zero  :-\  :-\
Quote from: Andy B on 26 October 2012, 09:17:30
Humm, possible, but in those cases the number plates don't look right. This one looked perfectly normal you would see on an 03 plate car.  :-\
It does happen, just not very often :y
YZ250
I'm sure this is still the case. Chap that works with me has a private plate on retention that he can't put on his car as the plate prefix is newer than his car. He bought the plate with his initials on, not realising this was the case.  ::)
Maybe it was imported in 2003, although it was RHD
henryd
Quote from: tunnie on 26 October 2012, 10:06:12
Could of come back from Japan or the channel islands ???
other rides
Normally, if a car is registered part way through its' life you need documentary proof of the vehicles date of first registration elsewhere in the world, or a certification of "newness" from the manufacturer for it to get an age related plate of that year. If you don't have such documentation, it gets a Q plate.
Either someone has forged some documentation or it's a daft mis-spaced plate, IMHO.
Agree probably mis=spaced to look like an 03 plate
IainMcDade
Completely irrelevent, but i thought this was titled "old cars & new RUG" and was expecting a very different first post, tho what i expected is a mystery to even myself  ;D
Like a boss, only better.
Quote from: dbug on 26 October 2012, 16:14:10
Spacing was correct, for the new style of reg. Also with old system you needed 3 numbers, not two. It was clearly 2 letters, 2 numbers and 3 letters laid out correctly  :)
I missed my usual staff shuttle bus so went to a different place, tempted to go back at same time as this person was dropping someone off, next time try and get a photo  :)
Quote from: tunnie on 26 October 2012, 16:48:48
Numbers 1 through to 99 were also available. 1 to 20 were originally kept back by DVLA  :y
Quote from: Andy B on 26 October 2012, 16:50:57
Good point well presented  :-[
Like I say it looked fine, not the chav mis-spaced bodges you see. Hopefully I'll see it again
