Author Topic: horns dead  (Read 2178 times)
razzo
  • Crapital
    • 97 3.0 Elite
horns dead
« on: 27 October 2012, 18:09:48 »
car failed mot as the horns were not working, relay seems ok as i can hear it click & fuse is intact put a volt meter across horn terminals & get 0v out of one connector & 5.2v out the other, any ideas where to go from here? tis a 97 elite
Re: horns dead
« Reply #1 on: 27 October 2012, 18:53:19 »
Try unbolting them and clean up the mounting, reattach and try them again :y
Re: horns dead
« Reply #2 on: 28 October 2012, 08:18:51 »
You often get the wires corroding about an inch or so from the connector...
Martian
Re: horns dead
« Reply #3 on: 28 October 2012, 08:58:17 »
Just because the relay is energising, it doesn't mean the contacts aren't pitted to the point where they can't switch the high current required.
razzo
  • Crapital
    • 97 3.0 Elite
Re: horns dead
« Reply #4 on: 28 October 2012, 10:46:42 »
working relay swapped over from another car with working horns & still no joy
Re: horns dead
« Reply #5 on: 28 October 2012, 10:49:21 »
It does have a dedicated fuse, worth a check (fuse, IIRC, is just in the horn power circuit, not the circuit that energises the coils).
razzo
  • Crapital
    • 97 3.0 Elite
Re: horns dead
« Reply #6 on: 29 October 2012, 13:54:01 »
thanks for all the advice, turns out one of the wires had been trapped in previous life & had just been taped up, eventually corrosion set in & wire failed. So now have 12 months MOT on it, just one more question, i only managed to get one horn working as when i plugged in the second horn neither would work, disconnect second horn & first horn works. Not too fussed just curious as to why?
