I am in a very bad mood....
Started by JamesV6CDX, 27 October 2012, 19:07:59
Quote from: chrisgixer on 03 November 2012, 19:21:53
530d isn't quite that wise. Massive injectors cost a fortune just to refurb. Numerous pumps and filter in the fuel system all play up with proper miles. Multi link suspension bushes are a bugger to diagnose. Hedgehogs fail. Head unit and dash displays loosing pixels... And of course, don't forget the essential swirl flap ectomy.
And if auto the box can't take a chip upgrade.
Sp apart from that...
So all in all just like most other cars then?  :-X
Personally it's the E60 530D LCi M Sport Model that i'm interested in so will only comment on that.
Swirl flap blanks are cheap and easy enough to fit (inlet easy to remove)
Dash displays loosing pixels isn't something i've heard of although LCD panels will be available in the same way as the Sharp LCD panels are available for CID's.
I know there can be issues with the iDrive controller that sits in the rear wing and can get soaked and destroyed by leaking sunroof drain tubes that have a design fault that stops debris flushing through (they are crimped so narrower and get blocked), easily fixed just like we know how to keep an eye on Omega Scuttles!
Suspension, can't really comment apart from the fact that every Omega (4 in total) i've owned has had to have new shocks, springs, wishbones, pollybushes, donuts, droplinks etc etc to get them to drive how they should.....
DPF removal is also a viable option and should release a few more ponies.
henryd
Quote from: tunnie on 03 November 2012, 20:21:27
With LPG or a diesel, combined with DIY service + cheap parts, not a lot can beat the Omega in terms of running costs. Trouble is with 5 Series, I don't like any of the later shapes.
This is the only shape i like:
Thats my favourite Beemer as well,I had the pleasure of driving a E39 530D manual yesterday and what a cracking car :y :y
other rides
And these are no newer than the Omega, so why bother :-\ later shape are alot more expensive too
Quote from: VXL V6 on 03 November 2012, 21:16:47
Vanos failure, viscos fan failure, leaking door membranes... Then there's the BMW tax on parts and no trade club.
E60 is way too new surely..? £££££ :o
Broomies Mate
#34
Quote from: chrisgixer on 04 November 2012, 03:38:26
]Vanos failure, viscos fan failure, leaking door membranes... Then there's the BMW tax on parts and no trade club.
To be fair, if the car is still on the road it would more than likely have had the Vanos problem sorted (if the engine was a model affected) and also had a replacement viscous fan.  I have personally found BMW parts to be no more expensive than that of the Omega.  Sensors etc are similar in price.
That said, I suffered heavier costs for suspension parts due to them being Aluminium (V8) whereas the Derv models and 6Pot Petrols have Steel Suspension components, which, are comparable in cost to the Mig.
For James;
At the moment yes, but I'm hoping to run the DTi for another couple of years which would coincide with the current model reaching the second hand market in decent numbers as they come off leases, which in turn should push the price of E60's into more affordable (for me) territory.
EDIT: caws ov spwelling mushtakes
