Author Topic: Key fob wont stay programmed  (Read 6139 times)
takemineanywhere
  • swindon uk
    • 2000 omega2.5td cdx
« on: 28 October 2012, 12:55:43 »
 hi yall.i,ve been a member of this forum a couple of months now and this is my first post.my car is 2000 f/l 2.5td cdx auto.Recently the center locking has playing up.one day it works next day not.the other day i didn,t use car for 3 days.when i tried to start it the radio had turned itself on and flattened the battery.after charging and dismantling /cleaning key fob it worked perfectly,however next day not.when its not working the boot release on dash doesent work either.also when opening the door the buzzer sounds as if the lights are left on.i,ve put key in ignition turned on &pressed buttons several tmes &the locks dont go up &down.ive never done the paper clip test.would this help? if not do i need tech 2? if so who is close to me.i live in swindon.if any one can help i would be very gratefull.thanks,paul saunders.
2000 2.5td cdx        1985 bmwr80rt
Re: Key fob wont stay programmed
« Reply #1 on: 28 October 2012, 16:14:05 »
Is the battery connection in the fob loose - this can cause it to loose syncronisation, and the reset procedure in the user guide will manually resolve it.
If the entire central locking plays up, has some idiot been near the programming side of it with an illegal code reader, as I have seen this before.
takemineanywhere
  • swindon uk
« Reply #2 on: 28 October 2012, 17:22:48 »
i,ve had the car 2 years,not had a reader on it.the battery holderer dosn,t seem loose.iread in another thread to pack the rear of the battery with cardboard?also read that Martin Imber will service the fob very quickly.maybe i should do this.today after syncing the key it opened the doors  but not lock them & nor unlock the boot.dashbord switch also nothing.cheers
« Reply #3 on: 29 October 2012, 10:43:59 »
Sounds more like switch issues on the fob. Does the red led light up when you press the buttons?
takemineanywhere
  • swindon uk
« Reply #4 on: 29 October 2012, 12:57:19 »
there isn,t a light on the 3 switch fob
« Reply #5 on: 29 October 2012, 13:16:45 »
Sounds like its already had a new cover fitted. The light is normally between the Unlock and Lock buttons.
« Reply #6 on: 29 October 2012, 13:18:25 »
And if it's already had a new cover fitted it makes it even more plausible that the switches are "beyond their best" and the old cover was split from pressing them excessively hard
« Reply #7 on: 29 October 2012, 13:21:26 »
The ebay replacement covers are quite poor as well, too hard.
For this reason, for my own facelift fobs, I buy a GM replacement fob when my cases start to go.  But then I try to change the switches in time, before this happens :)
Bob G
  • Gloucester
« Reply #8 on: 29 October 2012, 20:26:27 »
 There is on my 2 anyway, between the open and close buttons, also the repair kits on that well known site mention the red LED as well
takemineanywhere
  • swindon uk
« Reply #9 on: 30 October 2012, 09:49:30 »
I,ve just sent the fob to Martin Imber so when it comes back i,ll let you know whats happening.thanks for your help.
takemineanywhere
  • swindon uk
« Reply #10 on: 02 November 2012, 14:31:46 »
Just had an email from Martin imber,says the fob is good so something in the car is amiss.Any ideas,cheers Paul
« Reply #11 on: 02 November 2012, 16:26:35 »
Alarm ECU. But assuming it hasn't been molested by a cheap, illegal chinese code reader, they are normally ultra robust.
So I'd still say fob.
Do you just have the 1 fob?
takemineanywhere
  • swindon uk
« Reply #12 on: 03 November 2012, 13:26:30 »
Yes one fob,one key
takemineanywhere
  • swindon uk
« Reply #13 on: 07 November 2012, 16:19:48 »
Just got the fob back.Martin says strong signal everything ok.It will not sync in the car.doesn,t do anything.Boot locked even on dashboard.What should i do now?Where is the alarm ecu?
« Reply #14 on: 07 November 2012, 19:24:22 »
Drivers kick panel
Page created in 0.046 seconds with 20 queries.
