Author Topic: Key fob wont stay programmed  (Read 6155 times)
Re: Key fob wont stay programmed
« Reply #15 on: 07 November 2012, 19:25:05 »
Can you get it to Brackley?
takemineanywhere
  • swindon uk
    • 2000 omega2.5td cdx
« Reply #16 on: 11 November 2012, 18:47:09 »
SORTED.Cleaned all fuses & relays.No change.Did Hilpers boot mod.Put key in ignition,turned on.Hey presto!Key resynced first push of the lock button.Anti theft light comes on now(didn,t before)& everything seems to be ok.Maybe someone can explain why Hilpers mod did this.
On another point,i did paper clip test& got 41-boost pressure low
                                                         64-fuel quantity control out of range
                                                         92-cruise control device circuit open or voltage high
Cruise control only ever worked once breifly 2 years ago when i first got the car(2000,2.5td cdx)how do i go about this.cheers Paul.
2000 2.5td cdx        1985 bmwr80rt
« Reply #17 on: 11 November 2012, 21:13:46 »
Can't answer your key problem.
41 - clean up the inlet, and the sensors
64 - oh dear. try a can of diesel magic in the fuel filter, if that doesn't sort it, "oh dear"
92 - prolly a knacked stalk.
« Reply #18 on: 12 November 2012, 13:24:58 »
Check also the wires at the base of the cruise stalk for breaks
takemineanywhere
  • swindon uk
« Reply #19 on: 14 November 2012, 01:23:18 »
Does the stalk need to come from a td.Thanks for all your help.
« Reply #20 on: 14 November 2012, 18:41:22 »
TD stalk is different to all others
